Need help with type r Intake Manifold
use the obd0 injectors...the type R injectors are saturated and won't work...the obd0 injectors are the same flow rate as type r injectors anyways so there isn't any reason to change them...try that first.... if you changed to obd1 then you can run the type R injectors just be sure to remove injector resistor box...
