need help with toyota swap
Old 04-12-2004, 05:39 PM
Michael12602's Avatar
Michael12602 is an unknown quantity at this point
Default need help with toyota swap
my friend has a 95 tercel and bought a swap its the 5e motor its suppose to be a jdm motor the motor that is in the car has a no distributor and uses coil packs the motor he has uses a distributor what does he have to do to make this work anyone who can help out and he has already had several people look at this
Michael12602 is offline
Old 04-12-2004, 05:51 PM
brake/steer/throttle
ToyotaTechGeek's Avatar
Default Re: need help with toyota swap
go to u-wrench it and get a wiring harness from a newer tercel or paseo and the ecu also. use those.
ToyotaTechGeek is offline
Old 04-12-2004, 06:18 PM
i actually miss understood him i was in a hurry his motor has two coil packs and the motor he wants to install has 4 coil packs sorry bought the mix up
Old 04-13-2004, 05:49 AM
PJ2
PJ2's Avatar
PJ2
He needs to keep the set up that matches the ECU he is using or plans on using, he can actually use either of the coil packs if he wires it right but that's a little complicated. The waisted spark set up he has now should work with the new motor with no probs.
PJ2 is offline
ProbeGT-ZE
12-13-2008 07:51 PM
mikesmith611
03-10-2007 03:10 PM
aSlacker8
02-17-2005 06:30 PM
Jestible
09-04-2003 12:48 PM
Quick Reply: need help with toyota swap
