need help with temp gauge and gas guage
Old 09-07-2006, 11:17 AM
solocrxcivic's Avatar
solocrxcivic has disabled reputation
Default need help with temp gauge and gas guage
i just bought a 89 civic si and im having problems with the temp guage and gas guage. when i start the car up the temp guage shoots staight up to H and my gas guage does what ever it wants to it doesn't just up and down it just reads empty when i just filled it up and vice versa can any help me ? i dont know if a wire is crossed or a wire or wires aren't hooked up any help would greatly appreciated
thanx in advance for the help
solocrxcivic is offline
Old 09-07-2006, 11:25 AM
Classified Moderator
Fobby's Avatar
Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby
Default Re: need help with temp gauge and gas guage
possible problems on the temp gauge
1.bad thermostat
2.air in cooling system
3.very low on coolant
Fobby is offline
Old 09-07-2006, 12:18 PM
how do i check for coolant in the system? i changed the thrmostat two months ago. what about the gas guage is there a sensor where they both hook up besides the back of the guage cluster
thanx
Old 09-07-2006, 12:28 PM
Grrrrrrr!
BigCheese's Avatar
BigCheese has disabled reputation
thanx
There isn't a sensor but you could always pop off the cluster and make sure that the plug is in good. When I switched out my cluster my guages were acting weird because the plug was not plugged in securely.
BigCheese is offline
g S x
09-22-2008 04:51 AM
DORKO
07-23-2006 09:54 PM
Quick Reply: need help with temp gauge and gas guage
