need help OBD0 EF intake air temp sensor
hey everone i can not find anywhere where the pin out to the iat sensor is on a obdo ef body style car. my car runs good but just has that code and have done changed the sensor 3 times please any help. i was goin to wire in direct to the ecu. i had to also do that befor with another car wire stuff direct. please any help to fix this will make me real happy lol
i pooped a squirrel
Re: need help obdo ef iat sensor
first. some advice to make your experience here much better, and aid you in getting answers
edit that post, correct it grammatically, and form complete sentences that are actually coherent. and request a mod to fix the title, at first glance it looks like an epileptic seized while trying to make a thread
Re: need help OBD0 EF intake air temp sensor
i am not trying to be a dick i just needed some help.i am not trying to make anyones life any harder,just wanted a little info on if anyone had any. if u dont like the post hit the back button
Eat A Dick
hows your car's idle? the iat and iacv plug are on the same portion of the harness and the plugs are interchangeable. maybe you have them switched if you've replaced the sensor already.
next step would be to take a multi-meter and see if theres continuity between the iat and whatever pin it goes to at the ecu.
ya i thought i mixed them up to but i will check tommorw with my fluke meter and it idle good goes has no power when it is under a load and that is the only code i got checked timming and spark already that was all good
The IAT sensor is a two-pin plug,and can also be interchanged with other sensors as well(coolant temp,for example),as said above.Look up a schematic for your car and use the wire colors to ensure the proper plugs are connected to the proper sensors.
The wonders of the intarnetz.I Googled "OBDO Civic ECU pinout".Shit is crazy.
Is the car MPFI or DPFI?
MPFI:
List with both:
MPFI:
List with both:
lol ok thanks for the list i have already found but where is the iat sensor pin out? nvm i found out that they call it a TA sensor on the list thank you everone for your help.
