need help with massive oil leak (b16)
Old 05-17-2010, 09:44 PM
aec07716's Avatar
aec07716 aec07716 aec07716 aec07716 aec07716 aec07716 aec07716 aec07716 aec07716 aec07716 aec07716
Exclamation need help with massive oil leak (b16)
I recently replaced the head gasket, timing belt, water pump, and tensioner. Shortly after I started the car, I noticed oil leaking under the car..a lot of it..within 5 minutes almost all my oil was drianed..I quickly turned the car off, and havent had time to diagnose the problem. Before any work was done, there wearnt any major leaks or issues and it ran fine. I dont know where to start..any help would greatly be apprecited..thanks in advance
aec07716 is offline
Old 05-17-2010, 11:03 PM
Default Re: need help with massive oil leak (b16)
So you left the engine running for 5 minutes with a massive oil leak? Very intelligent.
Have you looked around to see where the oil is coming from? It's going to be something simple. Oil doesn't just pour out of properly assembled or properly maintained engines for no reason..
Old 05-17-2010, 11:05 PM
CPL Us Army
jpick_aap_cpp's Avatar
jpick_aap_cpp has disabled reputation
Forget to tighten the oil filter? or put the drain plug back in? What kind of work was done to the b16 before this oil leak?
jpick_aap_cpp is offline
Old 05-18-2010, 03:43 AM
NISSAN <3
JDM180SX's Avatar
JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX JDM180SX
once you figure your massive oil leak out...send the data down to the gulf...they could use some help.
JDM180SX is offline
Old 05-18-2010, 03:58 AM
NAZI mod
BAN HAMMER's Avatar
Mega lulz.
Just re-trace your steps OP. cant be that hard to figure out
BAN HAMMER is offline
Old 05-18-2010, 09:33 AM
aec07716's Avatar
thanks for all the input..if the rain holds out today Ill try messing with it....hopefully it will be as simple as it seems
aec07716 is offline
Old 05-18-2010, 09:46 AM
Dickbutt #peentip
Kris.Is.Foamin's Avatar
Holy lolz
Kris.Is.Foamin is offline
Old 05-18-2010, 03:17 PM
Marthewicked's Avatar
Marthewicked has disabled reputation
"Forget to tighten the oil filter? or put the drain plug back in? What kind of work was done to the b16 before this oil leak? " pretty much what i was about to say. trace the oil back obviously you see the oil and all
Marthewicked is offline
Old 05-18-2010, 03:53 PM
Shoryuken!
Snoop 95's Avatar
Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95
A B series Honda head gasket installed backwards (or upside down) will cause this. If you see a little tab sticking out from the tranny side front of the motor, its on upside down, & the VTEC oil passage way will be open, & you will lose all your oil in a VERY short period of time.
Are u 100% sure you installed the gasket correctly? Where exactly was the oil coming from? The bottom of the car, or was it by the back bottom of the head between the block.
Snoop 95 is offline
Old 05-18-2010, 07:55 PM
DJ CSI
D1NONLYJV43's Avatar
D1NONLYJV43 has disabled reputation
Start off by checking the drian plug making sure its snug n tight whichever and make sure its just not sitting there stripped.... Then start by taking off oil filter inspect it making sure its the correct one and the o ring on the filter is stil on it n there isnt an old o ring from the old filter stuck on it leaving you with two o rings....Once you ve done that clean and what i mean by clean is spray the bottom of oil pan and bottom of engine with brake parts cleaner or engine degreaser (Safiest method) engine degreaser cleaning all the old residue left on there to give you a clean slate to start with... Fill engine to correct capacity of oil needed ..... lay a peice of card board underneath start vehicle for a few seconds until u get some drippage and see where u get so far,.,.....
D1NONLYJV43 is offline
Quick Reply: need help with massive oil leak (b16)
