need help honda peoples codes
yo what going on i have a crx with a obd1 gsr..i have a obd1 dizzy i repin to make pre obd im flashing 3 codes #4 crankshaft position #9 no.1 cylinder position and #21 vtec..... i can do the vtec stuff but the other 2 are whats killing me so if some 1 know somthing i dont please post up here or send me a pm to help me out
thanks
thanks
Team Ultraspeed
Re: need help honda peoples codes
Are you running an OBD1 ECU with that OBD1 distributor? Because you can not repin an run a OBD1 distributor to run with an OBD0 ECU.
The tooth count of the crank angle sensor inside of the OBD0 distributor is different than an OBD1 and will never work correctly.
