need help with dohc zc asap
Old 07-03-2007, 06:54 PM
sibluecrx's Avatar
sibluecrx has disabled reputation
Default need help with dohc zc asap
got a 8 crx si, with a dohc zc, just got a brand spankin new distributor put it in, and started the cuz up idles ok. but when i took it for a test drive, at around 3200rpm it seems like im hitting the rev limiter and its like it cuts on and off, and then the check engine light came on with a code 4,8, and 9.....need some help please
sibluecrx is offline
Old 07-03-2007, 07:15 PM
streetsk8er757's Avatar
streetsk8er757 has disabled reputation
Default Re: need help with dohc zc asap
4 is crankshaft position sensor
8- topdead center
9 cylinder sensor
90% sure it could be the little sensor infront of the distributor on the head
if you need help pm me for my #
streetsk8er757 is offline
Old 07-03-2007, 07:27 PM
sibluecrx's Avatar
you mean the cam sensor?located on the exhaust cam?
and also i never had any of those codes until i put the new distributor on...its brand new?
Old 07-03-2007, 07:54 PM
12secondeg's Avatar
12secondeg is an unknown quantity at this point
what dizzy did you buy? you need a 88-89 teg dizzy. and when i switched my dizzy on my old zc, the plugs needed to be plugged in in a different order than the original dizzy i took off.
12secondeg is offline
Old 07-04-2007, 06:34 AM
formerly si_zc_civic
fwd_josh's Avatar
fwd_josh is a splendid one to beholdfwd_josh is a splendid one to beholdfwd_josh is a splendid one to beholdfwd_josh is a splendid one to beholdfwd_josh is a splendid one to beholdfwd_josh is a splendid one to beholdfwd_josh is a splendid one to behold
what he said. you need the 89 teg dizzy and a re-pin if you had an Si.
fwd_josh is offline
Old 07-04-2007, 06:40 AM
sibluecrx's Avatar
thats what i got a brad ew 89 teg dizzy, but all the wires on the new dizzy are completly diff
Old 07-04-2007, 07:34 AM
The cam sensor has 2 sensors in it and they should be the top dead center and crank position sensor
Old 07-04-2007, 06:07 PM
sibluecrx's Avatar
ok ...ya and i did have 2 wires on the dizzy mixed up so got it fixxed and workin now
k20egr
Want to Buy / Trade ARCHIVE
08-06-2008 04:28 PM
Quick Reply: need help with dohc zc asap
