Need help with a coolant leak......'96 Accord LX 2.2
Old 12-13-2010, 08:43 AM
<----BigBake
LXative's Avatar
LXative LXative LXative LXative LXative LXative LXative LXative LXative LXative LXative
Default Need help with a coolant leak......'96 Accord LX 2.2
Working on this for a friend.......just trying to keep it going as long as possible. Its a non-VTEC 2.2 liter.....and the coolant leak sometimes doesn't show its face.
Quick brief: sometimes this thing idles crazy.....up to like 2000rpms sometimes. Not something I'm too concerned about right now......I want to fix her coolant leak. Sometimes it will start to overheat a little bit when shes driving, even down the road at speed. The fans work, and the coolant seems to be pretty clean.
The leak: I looked the other day and couldn't find a damn drop of coolant under her car. I woke up this morning and looked out in the street, there was a small puddle underneath the car. I popped the hood, and could see a somewhat steady drip......coming from the backside of the engine, close to the timing cover. I pulled it in my garage and onto some ramps, and confirmed the leak is coming from that area. There is part of the block that sticks out right there, so I can't see above it. I took my fingers and ran above where I couldn't see, and all I felt was sludge from the timing cover leaking....it didn't feel wet like coolant. The best I could tell, that portion of the block that sticks out.....it almost feels like there is a screw or a freeze plug in it. I'm hoping its the block drain or a weep hole for a failing water pump.
Anyone?
LXative is offline
Old 12-13-2010, 09:07 AM
<----BigBake
LXative's Avatar
Default Re: Need help with a coolant leak......'96 Accord LX 2.2
Been searching, looks like that is going to be the problem. I know I have a LX 2.2 non-vtec.......but how close is this DIY to what I have?
http://www.honda-tech.com/showthread...water+pump+diy
LXative is offline
Old 12-13-2010, 09:31 AM
The Pro to call.
HatefulMechanic's Avatar
Sounds like the dihydromonoxide flow motivator to me.
There is a drain for the weep hole that comes out right where you describe.
I would do belt, balance belt, and all seals while you are at it.
And install one of the balance shaft seal retainers.
HatefulMechanic is offline
Old 12-13-2010, 09:55 AM
<----BigBake
LXative's Avatar
Hondas are greek to me, I'm brainwashed BMW. What other seals do I need to replace, other than those related to the water pump?
Also, that link I posted is for the EX motor......I have the LX. How similar with that DIY be to this job?
LXative is offline
Old 12-13-2010, 10:25 AM
The Pro to call.
Pretty much identical. New water pump, both the timing and balance shaft belt, balance shaft seal, crank seal, cam seal, and yer done.
Old 12-13-2010, 02:24 PM
<----BigBake
LXative's Avatar
Thanks man. +rep
LXative is offline
aec07716
05-25-2010 10:21 AM
rsxkid
09-08-2007 08:44 AM
UrGrlGveMeDkBrn
09-13-2006 06:37 PM
Pimp96Accord
03-27-2003 08:38 PM
93foxbody
03-04-2003 06:01 PM
Quick Reply: Need help with a coolant leak......'96 Accord LX 2.2
