Need help car wont start or turn over
Old 11-03-2004, 01:36 PM
*moving on up*
skybluecrx's Avatar
skybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond reputeskybluecrx has a reputation beyond repute
Default Need help car wont start or turn over
I have a 88 crx dx and it wont start or turn over. I replaced the starter because i thought that could be it but that wasnt it. All that happens when i turn the key is all my gauges and my fuel pump cuts on like its supposed to but it wont start or turnover. Could anyone tell me wut could be the problem.
skybluecrx is offline
Old 11-03-2004, 02:23 PM
DESTROYS DONUTS !!
MORE IMPATIENT's Avatar
Default Re: Need help car wont start or turn over
could be the main relay....
MORE IMPATIENT is offline
Old 11-03-2004, 04:31 PM
*moving on up*
skybluecrx's Avatar
I need all the help I can get so any advice helps.
Old 11-03-2004, 05:16 PM
Say somm!!!
NastyNate's Avatar
NastyNate is an unknown quantity at this point
So it cranks?? If not then jump the solenoid, also test the ignition switch. If It cranks but dosent start, check the main relay, along with the dist for spark etc....if so check fuel pressure at the rail.
NastyNate is offline
Old 11-05-2004, 07:26 AM
02StratusSE's Avatar
02StratusSE is an unknown quantity at this point
most likely the ignition switch
02StratusSE is offline
Old 11-06-2004, 10:54 AM
*moving on up*
skybluecrx's Avatar
what runs to the main relay that could cause it not to turn over
Old 11-06-2004, 11:01 AM
pimpingreen13's Avatar
pimpingreen13 is an unknown quantity at this point
the same thing happened to me a couple of days ago in my integ and all it came out being was a broken connector on the solenoid.
pimpingreen13 is offline
Old 11-06-2004, 08:39 PM
Turbo? whats that
SolarEclipse's Avatar
SolarEclipse is an unknown quantity at this point
same thing happend to my hatch... replaced the relay and it started right up
SolarEclipse is offline
Old 11-06-2004, 10:54 PM
Got a new name.
GreySquirrel's Avatar
GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel GreySquirrel
Did you put the starter on yourself? If so, when you tightened the battery cable to the starter were you careful not to overtighten? I replaced mine awhile back and did that, it turned the entire post and wouldn't work till I turned the whole thing back about a 1/8 of a turn. Only other thing I would suggest would be to check the fuse under the hood for the starter and making sure the plug in the starter is fully seated.
GreySquirrel is offline
Old 11-10-2004, 07:56 AM
*moving on up*
skybluecrx's Avatar
any more suggestions?
Quick Reply: Need help car wont start or turn over
