Need help can't figure it out b18b
Old 04-05-2013, 09:23 AM
MUFF_DIVER's Avatar
MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER MUFF_DIVER
Unhappy Need help can't figure it out b18b
So I swapped a jdm b18b into my ef complete with intake mani throttle body and all..having an issue where it runs like crap and the intake manifold makes a popping sound..any ideas or solutions will be helpful..also the car had a usdm b18 LS in it before and it worked good..please help
MUFF_DIVER is offline
Old 04-05-2013, 09:56 AM
superuser
Computer_Nerd's Avatar
Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd
Default Re: Need help can't figure it out b18b
intake valve spring making the valve not close completely, resulting in a cylinder misfire. use an obdi or obdii scanner to determine which one if you can, that's the easy way.
Computer_Nerd is offline
Old 04-05-2013, 10:59 AM
MUFF_DIVER's Avatar
My car is an ef 4door it's obd0 ..can it be that I need to put my old intake manifold back on
Old 04-05-2013, 12:27 PM
EH2/3 hoarder
0bd2eg's Avatar
0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg 0bd2eg
This needs to be in tech talk.
But hey op, your firing order is wrong, fix your plug wires.
0bd2eg is offline
Old 04-05-2013, 01:42 PM
Mirrorimg's Avatar
Mirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to all
If the plugs are in the proper order, check the valve lash. It could be set too tight not allowing the valve to close completely. Make sure its within spec at TDC for each cylinder.
Mirrorimg is offline
Old 04-06-2013, 06:11 PM
96civicEK
Trinity001's Avatar
Trinity001 has disabled reputation
the way you're describing the problem is if its sucking air from around the map sensor, put your obd0 intake on the engine an make sure you don't have any air leaks anywhere or anything of that nature......or leave that intake an pull map off make sure o-ring is there an make sure you're using the map sensor on the firewall of the car an it has a true vacuum source
Trinity001 is offline
StuntinOutlaw
07-21-2006 08:14 PM
93Mr2
04-22-2003 03:26 PM
Quick Reply: Need help can't figure it out b18b
