Need Help! B16A swap wont run!
Old 04-07-2011, 12:23 PM
ZcDoHcSi's Avatar
ZcDoHcSi has disabled reputation
Default Need Help! B16A swap wont run!
I recently bought a 1990 Honda Civic dx hatch with a B16A swap. The car ran fine for about 3 maybe 4 hours then had to get towed home by a friends crx. While driving it I noticed every time I brought it down to idle it would try to bog out but manged to keep it running with a little throttle. I've changed the fuel pump, checked injectors, and it has a new fuel filter. I checked to see if it jumped timing but it didn't. New plugs and wires. The distributor that's on it reads TD-23U but i was told its the wrong one for the motor. Car ran fine with it but i would like to figure out the right one for this motor?? ECU=PWO.
Help on this issue would be awesome so let me know what you come up with. Mean time I'm still searching blindfolded for the problem.
ZcDoHcSi is offline
Old 04-07-2011, 03:08 PM
twinturbomeow's Avatar
twinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these parts
Default Re: Need Help! B16A swap wont run!
its prob the dizzy
twinturbomeow is offline
Old 04-07-2011, 03:22 PM
WEEEEEEEEEEE
TATTRAT's Avatar
TATTRAT is offline
Old 04-19-2011, 01:29 AM
ZcDoHcSi's Avatar
Car only runs when on incline hills and fuel pump barley feeds fuel. What could be my issue?? car has half a tank of 93.
ZcDoHcSi is offline
Old 04-19-2011, 08:45 AM
aacjohnc's Avatar
change fuel filter.....or bypass it to see if pressure goes up... check voltage to fuelpump...check fp relay.
aacjohnc is offline
Old 04-19-2011, 09:40 AM
Dough_Boy.'s Avatar
MAybe the fuel pump. If the pump is working but barely has pressure it has power. A filter would run it would just be a little harder to stop.
Dough_Boy. is offline
vaintegra
12-11-2004 02:33 PM
Three5Zero
06-05-2004 05:37 PM
calgone47
11-17-2003 06:00 AM
calgone47
11-16-2003 10:30 AM
jon
02-13-2003 07:47 PM
Quick Reply: Need Help! B16A swap wont run!
