Need help!! B1 head on A1 block
Old 06-01-2008, 06:43 PM
onlyonevi3t's Avatar
onlyonevi3t is an unknown quantity at this point
Default Need help!! B1 head on A1 block
I have a B18b1 head on a B18a1 block and i just swapped it in and the motor runs fine but at around 5000 rpm it doesnt really go any higher while driving. When in neutral the motor will rev as high as you want. Once its in gear going down the road you cant get anymore than like 5000. I have no clue what is going on it just feels like it is "taching" out at 5 grand. I had a b1 block in before and it didnt do this. i put the a1 block in and now its doing it. Any suggestions??
onlyonevi3t is offline
Old 06-01-2008, 06:51 PM
team703's Avatar
Default Re: Need help!! B1 head on A1 block
what year car? limp mode or possible timing off?
team703 is offline
Old 06-01-2008, 07:01 PM
Flesh Into Gear.
kanadaa's Avatar
kanadaa kanadaa kanadaa kanadaa kanadaa kanadaa kanadaa kanadaa kanadaa kanadaa kanadaa
What ecu?
kanadaa is offline
Old 06-02-2008, 01:06 PM
I believe the timing is off after talking to several people, i will try and let ya know
Old 06-14-2008, 12:53 PM
Its a p28 in a 93 del sol si. Reset the timing and still doesnt perform right
Old 06-14-2008, 07:59 PM
Str8EJ's Avatar
Str8EJ has disabled reputation
hmmm...p28 is a sohc vtec ecu.
b18b & b18a are dohc non-vtec motors.
why are you using this ecu? is it modified for use with this motor?
Str8EJ is offline
Old 06-15-2008, 08:21 AM
no its not modified for the motor but it ran fine before i put this block in
Old 06-24-2008, 06:23 AM
up
Old 06-24-2008, 06:32 AM
cleanEK's Avatar
Get a ls ecu, when I got my ls swapped into my car I ran a 99 Civic EX (d16y8) ecu for about 9 months and it wouldn't rev past 5000. Finally bought a conversion harness and ECU and ran like a dream.
cleanEK is offline
Old 06-25-2008, 02:34 PM
will try
BlackGsR
07-27-2008 08:29 PM
Quick Reply: Need help!! B1 head on A1 block
