Need help, auto 2 5spd swap 240sx
Old 08-02-2011, 07:28 PM
pickupguy89's Avatar
pickupguy89 has disabled reputation
Default Need help, auto 2 5spd swap 240sx
Located in newport news
for a 95 240sx
ok so im trying to get my auto pilot bushing out of my crank, i have tried everything and it wont come out.
this i tried:
bushing puller (broke one i have another now)
fill with grease and hit with a socket n ext.
pipe wrench.
if anybody that has done this before and is a master at it, can i have someone come over about 8pm tomorrow night and pull this shit out. would greatly appreciate it
text me @ 757-775-9223
pickupguy89 is offline
Old 08-02-2011, 10:14 PM
Previously Odyssey
Odysseus Prime's Avatar
Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime
Default Re: Need help, auto 2 5spd swap 240sx
I have used the bearing puller a couple times(but it was for a manual bearing.I did have to use the grease method for the one manual swap I helped work on.
Did the same thing with the socket and extension and had no luck. The grease kept leaking from the extension mating area and around the socket.
When you did this method, was the grease leaking past the socket?
Looked on zilvia or nicco and saw a guy that used a wooden dowel.
So we bought a pretty thick dowel from Michaels and had to shave it a little thinner with sand paper until it fit very snug inside the bearing. Packed the bearing cavity 100% full
of grease, and took a 5lbs mallet and hit it through the bearing like 6 times. The pressure from the grease popped it right out.
If that does not, get creative with a dremel, hammer, vice grips, screwdrivers. Just be careful. But the metal is pretty soft if I remember correctly, so it will not take too long
using a dremel
Odysseus Prime is offline
Old 08-03-2011, 05:24 AM
idk, ivebeat the shit out of it with the socket and alignment tool for the clutch kit. nothing it moving this
im just getting aggervated on this POS, trying to get this out for 2 days and no progress
Old 08-03-2011, 06:34 AM
Tap around the outside race of the bearing with a punch or something similar. Sometimes that loosens up any corrosion between the bearing and flywheel and then it will come out with the normal methods.
Old 08-03-2011, 09:39 PM
Previously Odyssey
You don't hit the actual bearing with the grease method. You make a tight seal and the pressure of the grease pushes the bearing out.
Old 08-04-2011, 02:24 AM
97Ek_coupe's Avatar
97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe 97Ek_coupe
http://www.youtube.com/watch?v=1xuR7T8G1Ys
not exactly being done with grease, but its worth a shot?
edit: heard bread works better, haha
97Ek_coupe is offline
Old 08-04-2011, 04:42 AM
Nah really? i know what im doing lol.
but i got it out last night with the grease method, i just bought a bigger hammer
Old 08-04-2011, 05:15 AM
Hijacker's Avatar
Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker
I've always had luck with the bearing pullers.
A trick I saw someone on NICO do was take paper towels soaked in ATF or some other hydraulic fluid, and pack it in. The more you pack in, the more pressure applied to the back of the bearing. He was using a ratchet extension to pack it in IIRC.
Hijacker is offline
Old 08-04-2011, 07:31 AM
imSUPERjon's Avatar
imSUPERjon has disabled reputation
I used toilet paper and water. It took a little over thirty minutes and half a roll of charmin (like 3 ply or something) but stuff it in there, stick a 3/8ths extension in there and hammer away. Some of it will squish out the sides and it gets messy but it will work. I did this on an SR20.
imSUPERjon is offline
Old 08-04-2011, 03:56 PM
thanks guys like i said, i did the puller and just went back to my first attempt with the grease and 14mm socket n bang the hell out of it and after the 6th try it came loose
Blaznkwest
07-01-2004 08:00 PM
Michael12602
04-13-2004 05:49 AM
s2kattracks
07-20-2003 07:11 PM
B18Tuner
12-12-2002 02:02 PM
Quick Reply: Need help, auto 2 5spd swap 240sx
