Need help ASAP!!!!
Old 05-19-2003, 05:35 AM
emmett18
94b18c1's Avatar
94b18c1 has disabled reputation
Question Need help ASAP!!!!
OK I am stuck at my sisters house in Nova. my car is stuck in netrual, i went to go put it in reverse, and it felt like the gear shift fell out of place, and now i cant get t into gear, please help.
is it the shift rod/link or gear selector or what.
HELP
94b18c1 is offline
Old 05-19-2003, 06:09 AM
Bitches get Stitches
sk8rmike's Avatar
check the linkage under the car and make sure everything is bolted up there...if thats fine, then pull up your shift boot and check the shifter and bushings to make sure a screw hasn't come loose...
if those aren't it then i would assume it's something inside the tranny...
sk8rmike is offline
Old 05-19-2003, 06:11 AM
hybrid no more :(
Bert's Avatar
if it feels like the shifter is still shifting but there are no gears you got a broken ring...part of the shifer assembly in the tranny...only way to fix that is open up the tranny...happened to me 3 years ago...
Bert is offline
Old 05-19-2003, 06:28 AM
emmett18
94b18c1's Avatar
i can move the shifter in a upside down T shape, no shifting, i took apart the center console, cant see anything. where exactly under the car, its on a busy street so there isnt much time down there.
94b18c1 is offline
Old 05-19-2003, 06:46 AM
emmett18
94b18c1's Avatar
Default linkage
ok i checked under the car all linkages are together all from the shifter to the tranny are fine, so what can it be internally???
94b18c1 is offline
Old 05-19-2003, 08:47 AM
emmett18
94b18c1's Avatar
94b18c1 is offline
Old 05-19-2003, 10:12 AM
sk8rmike's Avatar
could be a lot of things...you just need to pull the tranny, open it up and look to find out.
sk8rmike is offline
Old 05-19-2003, 10:22 AM
Registered Offender
Mr. Rooney's Avatar
Mr. Rooney is an unknown quantity at this point
are you fucking kidding me? dont do all that yet.
check your slave cylinder. make sure it has fluid.
Mr. Rooney is offline
Old 05-19-2003, 02:16 PM
emmett18
94b18c1's Avatar
word from the shop is my tranny is shot. slave cylinder and master are new. i think something just came off track inside somewhere.
94b18c1 is offline
Gold Eg
Want to Buy / Trade ARCHIVE
11-13-2008 07:12 AM
Quick Reply: Need help ASAP!!!!
