need help
Old 07-19-2011, 09:29 PM
outlaw122504's Avatar
outlaw122504 has disabled reputation
Default need help
I just picked up this coupe that has a jdm d15b. The car starts and runs fine and idles good. I can rev with no issues soon as I take off it sputters and pops. Timing is good wires and plugs are to. Once I'm going down the road it runs fine just does it under acceleration in low rpm. As I get up in rpm it clears up
outlaw122504 is offline
Old 07-20-2011, 03:04 AM
superuser
Computer_Nerd's Avatar
Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd Computer_Nerd
Default Re: need help
maf, air-fuel mix likely too rich.
Computer_Nerd is offline
Old 07-20-2011, 08:08 AM
I'd be seriously impressed if you can find the MAF on a D-series Honda.
It will be a MAP sensor. It's also possible the throttle position sensor has failed at the bottom end of its range, which is a common problem because that's where it spends most of its time.
Old 07-20-2011, 08:13 AM
A.K.A Jebus
Scotty_Nooo's Avatar
Fuel pump could be going out or there is fluid disrupting the connection between the spark plug wires and the plug.
Pull the spark plugs and take a look at them, then post what color the plugs are at the tip.
Scotty_Nooo is offline
Old 07-20-2011, 08:24 AM
L_U_C_K's Avatar
L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K L_U_C_K
TPS and MAP may be switched.
L_U_C_K is offline
Old 07-20-2011, 08:27 AM
A.K.A Jebus
That would cause the idle to be off IIRC, this seem to only be when the car in moving.
Old 07-20-2011, 08:34 AM
L_U_C_K's Avatar
My Idel was Perfect when mine was backwards. Just wounld not rev accelerate past 300 and itwould spit and sputter
L_U_C_K is offline
Old 07-21-2011, 12:00 PM
Could it be fuel pump when it comes on its starts high the. Drops down like HMMMMMhmmmm its not constant like when it first primes
Old 07-21-2011, 12:02 PM
The sound will change because the pump is under load once the fuel system is up to pressure.
Old 07-21-2011, 12:03 PM
MARK IT ZERO
ufctapout's Avatar
Lugnut.
ufctapout is offline
emohodge
12-31-2002 02:46 PM
93foxbody
12-24-2002 10:33 AM
scubaskim
12-19-2002 05:52 AM
B18Tuner
12-12-2002 02:02 PM
matthew senski
11-30-2002 12:17 PM
Quick Reply: need help
