My Integra gsr not running right
Old 06-10-2012, 05:43 PM
jayrod360's Avatar
jayrod360 has disabled reputation
Default My Integra gsr not running right
I just bought a 95 integra gsr, i had it for a couple of weeks now. A couple of days ago it started to feel like it its losing power sometimes. When i first start the car it will run awesome and to its full potential, but when it gets warm it starts to feel like its losing power until i hit around 4500k. When the car gets warmed up it gets so slow that it feels like im going to bog out in first gear
Please help Mechanics
jayrod360 is offline
Old 06-12-2012, 04:47 AM
Keeping It Real !!
ravenracer's Avatar
ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer ravenracer
Default Re: My Integra gsr not running right
Modifications ?
How many miles ?
For now
- Check your spark plugs and connections
- Do leak down test for each cylinder
ravenracer is offline
Old 06-12-2012, 04:50 AM
Flatulence
PicovAndropov's Avatar
PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov PicovAndropov
What ravenracer said. Run a compression test. Also check to see if your timing is right
PicovAndropov is offline
Old 06-23-2012, 11:54 AM
ImKrue's Avatar
ImKrue has disabled reputation
Since you just bought the car, have you changed any of the fluids? Try that out. May not help but should always change your fluids when you get a new car.
ImKrue is offline
Old 06-23-2012, 12:52 PM
N2OWNED
99formula's Avatar
99formula 99formula 99formula 99formula 99formula 99formula 99formula 99formula 99formula 99formula 99formula
Changing the fluids is not going to make the car stop losing power. It's good to do, but really bad advice as far as what could be wrong with the power loss issue.
99formula is offline
Old 06-28-2012, 01:52 AM
4drsmorewhores
hype_r's Avatar
hype_r has disabled reputation
had the same problem with my gsr ej8. CEL would come on and off, checked the light and i had random misfire in cylinder 1 and 4.
hype_r is offline
Old 06-28-2012, 06:06 AM
Test your coolant temp sensor. The one going to the ECU, not the sending unit for the temp gauge. Test it while cold and while hot.
Also test the MAP sensor and TPS while you're at it, just to be thorough.
ARBizzle
09-14-2008 03:44 PM
98chase
08-14-2005 05:40 PM
90 hatch
04-05-2005 10:54 AM
NASTY68
10-02-2003 07:32 AM
Quick Reply: My Integra gsr not running right
