My g-friend's 95 2.3 dohc prelude oil leak.
Full Retard
I don't know shit about Hondas and hers is leaking like a bitch. It seems to be leaking up high somewhere. I saw oil pooling on top of the block on the drivers side rear of the motor so I changed the valve cover gasket and it seems to keep coming back. I heard the cam seals like to leak or maybe it's the head gasket. Got any suggestions for me, or Anyone good with Hondas on the peninsula want some side work or wants to give me a hand with it let me know.
Thanks
Thanks
Re: My g-friend's 95 2.3 dohc prelude oil leak.
Is it over-heating? Is it running normal? Coolant-oil mixing? Do a compression test and if it's anywhere near low it can be sign's of a head gasket leak. If you have the access to this..Get a Ultra-Violet (U/V light) get some oil dye, put the oil dye in her car, let her drive it for a little bit, Usually takes a hundred miles or so and then check for any signs of the oil Dye with the U/V light and it will let you know where it is coming from.
Prelude Whore
pictures please? I cant quite make it up to you since my lude is OOC at the moment
oh and its a 95 Prelude Si.....lol
H23 DOHC non Vtec.....
Full Retard
It isn't over heating and seems to run fine. Just leaking quite a bit of oil and right over top the exhaust of course to create quite a smoke show. I've had plenty of experience with bad head gaskets on all the Fords I've owned and don't think that's what this is, but really don't know how many other things it could be leaking down onto the top of the block.
Full Retard
Originally Posted by tie fitr
Actually I think it's a 95 Prelude SE 2.3 dohc non vtec. That's what it says on it anyway.
Full Retard
Originally Posted by DOHC crx VTEC
Yeah the motor code is H23 though....Well are you able to take a pic of it? It could be improper Valve cover gasket installment as well as it could be a slight leak in the headgasket or cam seal?
I can take a pic tonight. I don't think I installed the valve cover gasket wrong. I bought a new gasket and used black RTV in the corners around the cams. I don't feel like doing the cam seals by myself either, so That is why I'm asking if any one on here wants to do it or help me do it.
Well, Best advice, take a pic and we will go from there!
Full Retard
