msd problems
msd problems
i just hooked up a external msd coil with the cap and on high rpms the car bogs out, thinking the 14 guage wire from the distributor is to small, ran out of ideas, if anyone could help thanks
braap braap
Re: msd problems
Just out of curioustiy. What car is this, and other mods.
Also, was it doing this before adding the coil?
Did you hook up a 6al, or one like it, box? Or just a external coil? Maybe the coil is bad.
I need a little more info. before I can help you.
Re: msd problems
its a gsr, turbo, fuel pump, fuel rail, exhaust, it was not doin this with the stock coil, and its the just external coil, im gonna try thicker wire tomorrow, just wanted to see if that would be the problem
braap braap
Re: msd problems
IMO, I'd use the stock setup.
Re: msd problems
Originally Posted by Jarrod
To be honest. The factory Honda igntion setup is fine, you do-not need to upgrade it. And without the box, you won't see any gains over the stock setup.
braap braap
Re: msd problems
Originally Posted by LS-T EH3
my car idle'd smoother with coil, no power gains tho
BTW, I'm not being a ass about it. I understand you have your fair share of work done to your car.
Re: msd problems
the car felt like it was misfiring with the stock setup, so i figured i needed better spark, it runs smoother in low rpms but when i got on it, it felt like it would cut out, so thats why im thinkin the wires from the distributor is too small
