motor help
Old 08-09-2008, 07:58 AM
hatchback91joey's Avatar
hatchback91joey has disabled reputation
Default motor help
hello everyone what i need is to know if my ecu is bad would it make my car run and have no power what i am sayin is it starts up and runs but when i hit the gas and it just has no power could it be that my ecu is bad
hatchback91joey is offline
Old 08-09-2008, 08:42 AM
DESTROYS DONUTS !!
MORE IMPATIENT's Avatar
Default Re: motor help
if your ecu is "bad" it usually wont let the car start, if it does it will run like bootycakes. theres multiple reasons as to why you dont have power when you hit the gas. do you have and check engine lights at all ? if your ecu is bad you should have a permanent check engine light on. looking at your user name im going to assume you have a 91 civic hatchback, look at your ecu, if the red light is on permanently and wont go off, you need to replace the ecu. if its blinking you need to check which codes are flashing.
MORE IMPATIENT is offline
Old 08-09-2008, 09:49 AM
misunderstood.
s2katin's Avatar
s2katin s2katin s2katin s2katin s2katin s2katin s2katin s2katin s2katin s2katin s2katin
Run-on sentences are the fuckin best!!!! English helps.
Lolololol at bootycakes.
s2katin is offline
Old 08-09-2008, 11:01 AM
Sounds like a sensor problem, or likely a wiring problem if the engine is swapped.
slow40sx
Engine / Exhaust / Drivetrain
03-24-2009 10:37 AM
Gadianton Racer
Other ARCHIVE
10-04-2007 01:30 PM
Quick Reply: motor help
