Mini me oil to turbo help?????
Formerly Shinobi....
Ok the turbo kit is 99% done but when we went to hook up the fitting for the oil preassure sending switch, all there is is a bolt.....No plug no nothing.....Its a 96 DX block with VTEC head..... Do we just pull that bolt out and put the fitting in there or what? Please help someone.......
Re: Mini me oil to turbo help?????
Should not have found it you mean. You need to take out the oil pressure sending unit and use a t-fitting and line goes to the turbo.
Currently N/A
Sounds like you have the wrong "bolt". The oil pressure sending unit is just above and to the left of the oil filter. It's a bitch to get to, but there should be one wire leading into it. You'll need to remove the whole sensor and get a 1/8" NPT "T" from a hardware store so that you can hook up both your sensor and feed line. Be careful not to crossthread the block, it's a pain in the ass from the angle you have to do it. Good luck.
crznx2000
Engine / Exhaust / Drivetrain
03-09-2009 04:17 AM
spnamnt
01-19-2008 08:02 AM
