Mini me on GAS!? will it hold?>
ok so ive got a 90 crx with a mini me swap in it. its got the d15b7 bottom end with a d16y8 vtec head on it. its got a couple extras like intake, exhaust, header, injectors, and aftermarket fuel rail. im really wantin to put a dry shot of nitrous on it. i was THINKING a 50 shot? would this hold together pretty safely? or would i need to do a smaller shot or would it hold more than a 50? im kinda new to nitrous so im just wondering if any of you guys could give me any suggestions?
Re: Mini me on GAS!? will it hold?>
You should leave it the fuck alone and enjoy good gas mileage considering the prices are so high. Nitrous is gonna wear that bitch out quick too.
RIP DRAGVA-2016
Type-R; Tight Car
A dry shot on a d-series is going to get annoying as fuck. I used to have a 50 dry shot on a z6 and I would burn up #3 cylinder valves almost every time I went to the track. That means a new head gasket and valves every time you spray for too long and don't give the cylinder time to cool down.
At the MOST I would use a wet 50 shot or a dry 35 shot. D-series sucks for nitrous if it's not built.
Type-R; Tight Car
It's a D series. It wasn't built with the intention of people putting nitrous in it. It was built to get good gas mileage. I don't even know why people fuck with them? A reliable 40ish mpg is way cooler than having a D series on the spray that might not make it to walmart that's five minutes down the road.
An engine is an engine and the reason people put nitrous on a d-series is the same reason a redneck puts nitrous on an LS1. And if you think d-series only purpose is to get 40mpg then go talk to the thousands of people making 300+ hp out of them with minimal money dropped into them.
A d-series is a great motor for whatever you want to do with it, all I'm saying is in stock form he's going to run into issues with too big of a shot. The d-series valves have less inconel/less material in them than the b-series valves so they can't resist very high cylinder temps for an extended period of time. I'm all for nitrous, back in the day a dry 50 shot turned my 16 second car into a 13 second car for a couple hundred dollars. Just make sure if you are going to spray to build the motor for what you are doing. If he wants a stock d-series with nitrous then a dry 35 or wet 50 shot is as far as I would go. These days you can tune for these things much better than when I had nitrous. Also, he can still keep his 40mpg's with the bottle off.
And btw, you can still drive to Walmart with a chipped valve
