Mazda Problem Need Help
Old 08-05-2003, 03:50 PM
The Dune Coon
one pnt 8 hatch's Avatar
one pnt 8 hatch is an unknown quantity at this point
Default Mazda Problem Need Help
aight i jus bought a 93 mazda mx6 2.o 4 cylinder. i need the firing order for the thing. it wont start and i jus replaced cap rotor and plugs. wires are still good. only time it starts is when the wires are on wrong. it sounds like a lawn mower. i need someones help please. the cap has the firing order on it and i follwed that and it wont start i dont know why. someone give me a hand here.
one pnt 8 hatch is offline
Old 08-05-2003, 07:48 PM
Zoom Zoom
Kaedenky's Avatar
Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky Kaedenky
Engine order from the engien is
Passanger side 1-2-3-4 drivers side
Firing order on the distributer is for m/t
21
43
for an a/t its
1 2 3 4
I I I I
that is a crappy pic of the distributer
Kaedenky is offline
Old 08-05-2003, 07:58 PM
Zoom Zoom
Kaedenky's Avatar
double post
Kaedenky is offline
Old 08-06-2003, 04:28 AM
The Dune Coon
i fixed that problem the cap or rotor is bad. but i got a new question, car jus shuts off in third gear ofter gunnin it in 1st and 2nd. any ideas?
Old 08-06-2003, 07:06 AM
Zoom Zoom
Kaedenky's Avatar
www.mx6.com :P
not to sure
shuts off like dies...chokes.....more of a description would help
Kaedenky is offline
Old 08-06-2003, 02:05 PM
The Dune Coon
jus cuts off like some turn off the car with the key
Old 08-06-2003, 04:33 PM
Zoom Zoom
Kaedenky's Avatar
Default beat your iac
Beat your iac with a rubber mallet some...somes like its stuck
Set your idle
otherwise i wouldnt mind coming to help you pm your phone and ill bring my manual to help you out
Kaedenky is offline
Old 08-06-2003, 09:22 PM
The Dune Coon
some one on mx6.com said to rebuild my distributor
Old 08-07-2003, 06:19 AM
StreetEvo's Avatar
StreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these partsStreetEvo is infamous around these parts
Iv'e got the same engine in my protege. I'll check the service manuals to see what it says about the whole shutting off deal. Also does it idle low sometimes when you're coming to stop? If that's happening, replace the spark plugs. I go through 2 or 3 sets a year b/c of that. The FS engine eats spark plugs, it goes lean at wide open throttle anywhere above 5k rpms.
StreetEvo is offline
Old 08-07-2003, 10:43 AM
The Dune Coon
wel the distributor jus went out today so i have to get a new one now anyway car wont start. so if anyone got a spare workin disty let me know
Quick Reply: Mazda Problem Need Help
