ls swap in crx help
Old 12-01-2009, 01:14 AM
1_bad_eg's Avatar
1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts1_bad_eg is infamous around these parts
Default ls swap in crx help
I put I obd1 ls swap in my crx dx dpfi.it started right up but is throwing a cyp and map sensor code.I have tried 2 dizzy's and 3 map sensors and still getting codes.I have already went back and check wires for good connections.I'm used my factory dpfi harness and just converted it ova.I'm running open header to.has anyone had this problem
1_bad_eg is offline
Old 12-01-2009, 04:16 AM
gsrhach's Avatar
gsrhach has disabled reputation
Default Re: ls swap in crx help
does it rev up fine and idle fine? the throttle position sensor and map and the same plug you could maybe have those two plug switched around also the wiring harness is a pain in the a when usuing a dual point injection harness
gsrhach is offline
Old 12-01-2009, 04:20 AM
1_bad_eg's Avatar
Yea I know the pluds are right cuz on a crx the map sensor is on firewall and I had to make I longer o reach
1_bad_eg is offline
Old 12-01-2009, 05:39 AM
JimmySteezen757's Avatar
JimmySteezen757 has disabled reputation
Good luck! same shit mine was doing. except it made me get 100 miles to the tank, maybe a little less
JimmySteezen757 is offline
Old 12-01-2009, 06:03 AM
How did you check the wires for good connections?
Have you checked that you're getting 5VDC at the sensors?
There are three things that can go wrong here:
  1. Bad sensor
  2. Bad wiring
  3. Bad ECU
Any other problem is a byproduct of one of those things.
Old 12-02-2009, 09:43 AM
1_bad_eg's Avatar
got cyp fixed still got the map sensor problem tho
1_bad_eg is offline
crxtyper
09-09-2007 04:05 PM
-Danimal
04-17-2003 10:57 PM
Quick Reply: ls swap in crx help
