low oil psi
low oil psi
Aight ppl i have a 99 gsr with an obd1 jdm gsr swap fully built head manley valve train pro series +1 cams port n polish valve job etc.... STOCK BLOCK... I have an oil psi problem 18 psi at idle and while im driving down the interstate the oil pressure fluxuates from in the range of 80 down to 50.. It never moved befor i had been running eneos and switched to mobil 1.. Im in the stages of buolding a block but i need to keep ole girl running and i dont want to throw a rod... Is there any chance i will damage the head
Re: low oil psi
Well if oil pressure drops your more likely for the engine to lock up than throw a rod. But the head does need oil to if the oil pressure is dropping and the head isn't getting enough oil yes it will fuck up the head.
VaDriven Mayhem
Re: low oil psi
Did you try a new pressure sending unit?
Is the oil pump going bad?
Did you troubleshoot at all?
Re: low oil psi
Ive replaced sending unit have not replaced pump dont know how and shop tryin charge 600 is that fair price.. Or you think theres a how to that could help me do it myself
Re: low oil psi
Is there a write up on this ive looked on honda tech google ci
Re: low oil psi
If you can't look at it and figure out how to do it you need to let someone else look at it.
VaDriven Mayhem
Re: low oil psi
For a how to, as Humongous said, get a Haynes, or try on Honda-Tech.
Re: low oil psi
Maybe i should have been a little more clear. Im geting a block built and i would like to save some money in the mean time so instead of forking out 600 to get an oil pump installed i was going to try it myself
