LOOK INSIDE HELP IS WELCOME
so i have a 1990 civic with a d16y8 swap that's not revving over 3200 rpms . was told it might be the crank angle sensor but not sure that's why i came to you guys for help . if anyone has any helpful info it would be greatly appreciated
NotAcOp:)
Re: LOOK INSIDE HELP IS WELCOME
No problem I'd say try a friends dizzy or something first and if that doesn't fix it then check the wiring for the crank angle sensor and check the wiring for the 2 new injectors u wired in cuz I had the same problem in my ef and the injectors weren't wired up right
great deal of help my friend , I'm no good with wiring
