Knocking noise from motor...HELP!
Old 12-03-2007, 08:22 AM
jbhondaeg's Avatar
jbhondaeg has disabled reputation
Default Knocking noise from motor...HELP!
hello everyone
I have a 95 honda civic with 102xxx. It makes a knocking/tapping noise on cold starts for about 5min. Once the engine reaches running temp it goes away. I am using 5w-30 oil and have adjusted my valves. This is the second winter that its doing this. Does anybody have ideas? thanks john
Video of noise...
http://youtube.com/watch?v=e4YodjJWUOc
jbhondaeg is offline
Old 12-03-2007, 09:03 AM
RandomTask's Avatar
Default Re: Knocking noise from motor...HELP!
Knocking and tapping are two different things. Knocking is more of a 'lets take a hammer and hit a metal plate' tapping is 'lets take a screw driver and tap on the same plate' . Seeing how its doing it in the colder months, could be you have a lifter going bad/collapsing. Just taking a while for the oil to come up to temp. Try a thinner oil (5w-20) and see if that helps at all.
RandomTask is offline
Old 12-03-2007, 09:49 AM
DAintegra90's Avatar
DAintegra90 has disabled reputation
+1 or if your using a lesser octane gas try 89 or 93
DAintegra90 is offline
Old 12-03-2007, 09:59 AM
go topless.
BillMW's Avatar
BillMW has disabled reputation
^^^ Yes it's the lifters. Check the oil pump as well. STP oil treatment may help reduce the tapping. Always wait for the temp to get to operating temps. Do not push the car over 3000 rpms until the temp is normal.
BillMW is offline
Old 12-03-2007, 10:19 AM
jbhondaeg's Avatar
The noise is fairly loud...I guess more of a hammer knock... Tomorrow morning I will try to post a sound clip or short movie clip so you guys can hear the sound.
Oh and it makes the noise once you apply the throttle...not at idle=no sound
Yeah I do use 87 octane but I thought that did matter since it’s not a high performance engine and im certainly not pushing it. As for the oil pump whats the best way to check that?
Thanks so far!
Old 12-03-2007, 10:46 AM
corona connessuer
CHAHONDA's Avatar
Thanks so far!
put it a quart of lucas engine treatment. that should help alot. sounds to me like you have a main bearing going bad or piston slap.
CHAHONDA is offline
Old 12-03-2007, 11:43 AM
r0tard
Verbal's Avatar
Verbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these partsVerbal is infamous around these parts
+1
-or-
Your oil pump is probably weak, when the air gets colder, the oil gets thicker and it takes longer to get where it needs to be.
Honda's have lifter's..?
Verbal is offline
Old 12-03-2007, 11:45 AM
Gustav's Avatar
Gustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these parts
There is only one problem with a couple of the theories here. IT DOESN'T HAVE LIFTERS! Double check your valve adjustments and make sure you do it when the engine is cold.
Gustav is offline
Old 12-03-2007, 11:51 AM
Gustav's Avatar
Thanks so far!
Sounds like a rod knock to me.
Gustav is offline
Old 12-04-2007, 06:36 AM
jbhondaeg's Avatar
I checked the oil fill cap this morning as soon as I started it and there was oil in the head splashing around. Tried to use a metal pole to distinguish were the sound was coming from, but couldn’t determine it...it almost sounds like a damn rattle spray can when u shake it just not as rapid and much louder. I am definitely going to get a short sound clip this evening when I get off work.
Quick Reply: Knocking noise from motor...HELP!
