-   -   Kaaz LSD problem (https://www.vadriven.com/forums/tech-talk-9/kaaz-lsd-problem-224142/)
disisaghettosn Feb 6, 2008 04:50 PM
Kaaz LSD problem
I installed the lsd and am having turning problems. If i accelerate while turning it kind of pops or skips, its not smooth. Does anyone know what this could be?
JDMS1eeper Feb 6, 2008 05:43 PM
Re: Kaaz LSD problem
Isnt that LSD like a welded diff? Like the Phantomgrip LSD
Fobby Feb 6, 2008 05:45 PM
you brake it in properly?
Fabrik8 Feb 6, 2008 06:56 PM
It sounds like you haven't broken it in properly, or at all. Clutch type LSDs will chatter at low speed until they are broken in, and are still a little chattery until all of the clutch plates mate properly. You could probably find break-in instructions (repetitive figure 8s usually) on one of the LSD manufacturer's sites, or on KAAZs site.
And don't use synthetic fluid, it lubricates too well and won't allow proper clutch plate mating...
KAAZ LSDs are nice, make sure you treat it well..
Cereal Jones Feb 6, 2008 07:01 PM
Break-in procedure at the bottom
http://www.nicoclub.com/articles.php?id=217546
WishIHadaSilvia Feb 6, 2008 07:06 PM
That is what Kaaz LSDs do. They're loud and it sounds like something will break when you turn at low speeds.
If you bought it new and installed it yourself make sure you set the backlash correctly. Other then that the only other thing you do is drive around for...I can't remember if it is 150 or 300 miles then change the fluid and break in is done.
They're loud and obnoxious, if you don't like that buy a helical diff.
Silverbullet86 Feb 6, 2008 07:23 PM
it could be your LSD is doing its job. :D
DecentCivicZ6 Feb 7, 2008 06:16 AM
obx9.2v lsd ftw
WishIHadaSilvia Feb 7, 2008 07:19 AM
LOL...a OBX LSD, are you kidding me?
Buy a Quaife if you want a good helical diff.
Shaminii Feb 7, 2008 07:26 AM
Sounds normal to me. Get used to it and quit being a bitch.
