KA24DE cam problem
KA24DE cam problem
Putting this DE back together. Bought the car with a smoked motor that had been taken apart by the previous owner and have since rebuilt. Putting back together now and haven't built an engine in years. Pretty sure I had the timing right but in acquiring parts for the motor I gained an extra couple cams. I need to know which two need to go back in. I have three marked 53F with a 3 stamped on them and one with 53F and 5 stamped on it. Right now I have 2 53F with 3's installed but number 4 cylinder is hitting the valves on rotation. I even tried the shifting the cam over 4 teeth and still the same(as I read somewhere in another post on zilvia somewhere). The problem seems to be the valves hitting the piston in cyl 4
Whats the next step?
Here are the timing marks as they are now
Here is an overhead pic of the cams
Here is a close up of Cyl 1
Here is a close up of Cyl 2
Here is a close up of Cyl 3
Here is a close up of Cyl 4
Re: KA24DE cam problem
No. 1 cam lobes should be facing outwards...
http://jimwolftechnology.com/wolfpdf...R%20KA24DE.PDF
What he said plus
Make sure you have the chain on right. Distance between black/marked links is not the same. longer one goes on the side of the tensioner.
Also don't forget once you turn the crank marks will not line up for who knows how many revolutions.
Edit: you have the upper chain wrong. should be SIX links between cam bears
Below is how it should look at TDC
from my exp they are interchangeable and are same on all KA's except that oddball year where it had a longer lift. but even that cam can be used on both sides.
on S14's Intake is Green
o shit shit shit. i am sorry exhaust is green .check pic above for reference. i got it mixed up. pic above is my old old ka build. either way this wont have any effect.
LSX240
Want to Buy / Trade ARCHIVE
09-07-2008 05:57 AM
TheMx3
02-03-2004 01:18 PM
