just turbo'd now got problems need help asap!
Old 03-17-2010, 10:27 PM
kulbordr's Avatar
kulbordr has disabled reputation
Default just turbo'd now got problems need help asap!
alright so i just got done turboing my integra and now im having problems. ive got a 94 integra with an ls engine, im running a pr4 chipped on chrome. i started the car and ran it for a bit but the problems started from there, my idle is bouncing from 1000rpms to 2500rpms, my oil pressure is bouncing between 75 and 50 and my vaccum is jumping between 10-20, any suggestions, oh and when i slow down just before i stop i get a belt squeal. any help would be appreciated
kulbordr is offline
Old 03-18-2010, 05:22 AM
I <3 Hikki Chan!
ProbeGT-ZE's Avatar
ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE ProbeGT-ZE
Default Re: just turbo'd now got problems need help asap!
Sounds like you've got a air pocket in the cooling system. That will cause the idle surge you're getting. Burp the cooling system better, that could help. Whenever the idle goes up and down the oil pressure/vacuum will fluctuate accordingly. So either you've got an air pocket or your IACV is going/gone.
ProbeGT-ZE is offline
Old 03-18-2010, 06:10 AM
kulbordr's Avatar
alright il try that out today, thanks.
kulbordr is offline
Old 03-18-2010, 07:16 AM
s14kouki's Avatar
s14kouki has disabled reputation
yea it does sound like the IACV is going bad. Sometimes cleaning them helps. worth a try
s14kouki is offline
Old 03-18-2010, 07:26 AM
Bitches get Stitches
sk8rmike's Avatar
if you screwed around with your intake manifold at all a vacuum leak there will cause the same problem as well.
sk8rmike is offline
Old 03-18-2010, 08:49 AM
BACK IN A G8
2ltrgsr's Avatar
iacv
2ltrgsr is offline
Old 03-18-2010, 04:55 PM
Stiff Member
Laserjock's Avatar
Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock
I had a massive leak between the head and intake manifold caused by a piece of gasket that caused those exact symptoms
Laserjock is offline
Old 03-18-2010, 11:44 PM
kulbordr's Avatar
yea i think that might be it cause my intake manifold gasket is fucked up
kulbordr is offline
Old 03-19-2010, 09:53 AM
That would do it.
The oil pressure and vacuum fluctuations are usually just products of the change in engine RPM.
You should get your ECU tuned for your particular setup, I hope you're not using a tune from someone other car... Even minor differences between one car and another are too much risk when you have a turbo setup.
Old 03-19-2010, 06:13 PM
kulbordr's Avatar
alright i fixed the vaccum leak it was the intake mani gasket...now ive got my boost gauge hooked up to my fpr im reading vaccum but not boost pressure, now i read on alot of other sites to run it there, but ive also heard that i have to run it between the turbo and the intake mani somewhere to read boost, that seems logical. i dont have a spot on my compressor housing to run it or i would whats another option?
kulbordr is offline
Quick Reply: just turbo'd now got problems need help asap!
