Integra GSR won't shift into gears since it's gotten cold.
Old 12-17-2011, 07:46 PM
IRR0MPIBLE's Avatar
IRR0MPIBLE has disabled reputation
Default Integra GSR won't shift into gears since it's gotten cold.
So I just got this car in March or April, thus I have not experienced cold weather with it. This just started today.
It shifts fine after warming the car up to normal operating temperature, but after driving for awhile in this cold weather, particularly after cruising in 5th for long periods, it won't go into the gears. ie, I will drive on the interstate for 35 minutes or more and then come to a stop somewhere and cannot shift into 1st. Any help is greatly appreciated. Thank you.
IRR0MPIBLE is offline
Old 12-17-2011, 09:30 PM
Temporary ######
Brian_O'Connor's Avatar
Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor
Default Re: Integra GSR won't shift into gears since it's gotten cold.
Sounds like your gear oil has gone bad and needs to be changed. When the oil goes bad it gets thick qnd when cold it makes it difficult to shift. Change it out with synthetic and your issue should be fixed.
P.S. If you had googled and had searched for 5spd will not shift when cold, you wouldn't have needed this thread.
Brian_O'Connor is offline
Old 12-18-2011, 09:15 AM
IRR0MPIBLE's Avatar
It actually ended up being that the clutch fluid reservoir was nearly empty. Put some dot3 in it and problem solved.
I actually did google before posting and came up with so many varying results, I made the thread. Theoretically, you could google anything that could be posted in tech talk, but people still make threads.
rberrydc2
Engine / Exhaust / Drivetrain
03-21-2011 06:41 PM
Natodu
05-01-2010 11:29 AM
Slepping_H22_DC
07-04-2006 08:25 PM
leolo007
03-17-2005 08:25 AM
Quick Reply: Integra GSR won't shift into gears since it's gotten cold.
