Integra Door Seal / Weatherstripping
Old 05-18-2012, 10:59 AM
myst's Avatar
myst is a jewel in the roughmyst is a jewel in the roughmyst is a jewel in the roughmyst is a jewel in the rough
Default Integra Door Seal / Weatherstripping
Does anyone have any experience with replacing the weatherstripping aka door seal on an integra?
I could use some pointers before I dive into this and accidentally rip the seals. Any help or suggestions is greatly appreciated.
myst is offline
Old 05-31-2012, 04:42 PM
Mr. Fixit
da93teg's Avatar
da93teg has disabled reputation
Default Re: Integra Door Seal / Weatherstripping
if you are replacing with brand new its very simple
grab one corner and pull off completely
there should be small plastic clips still in door sill take those out the new seal should have those on it install in reverse order making sure to push clips all the way in
once you pull the old stuff off you should have no problem with it
good luck
da93teg is offline
Old 05-31-2012, 05:43 PM
last breath first
gdupfromfeetup's Avatar
gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup
i used a thin pallette knife from work to take mine off. Just start from one side and slowly work your way to the other. Make sure you take off all the remaining seal!
gdupfromfeetup is offline
Old 05-31-2012, 06:54 PM
Whatever it takes
ls/vtecstitch's Avatar
ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch
anyone know of a good site to get replacement seals from? the dealer no longer carries mine for my 1992 four door integra.
ls/vtecstitch is offline
