Integra brakes/suspension conversion for CRX
I'm doing the Integra brakes and suspension conversion for my crx and was told that i need an e-brake cable from a EF civic hatchback si. I was also told that i could just use the integra e-brake cable. If anyone knows or has done this conversion I would appreciate it if you could help me out, thx.
Captain Deeeez Nutzz
Re: Integra brakes/suspension conversion for CRX
I believe all of those will work. ef hatchbacks all had rear drums so you can't use the e-brake cable from it. 91 crx si's had rear discs and you could use those cables if you can find them.
you can use any of the rear disc brake cables but the best way is to swap the sides from when it is running into the e brake lever to make it shorter
