Indash brake light on while driving
Old 12-29-2006, 08:41 PM
U LòÓk Mad !!
CarShowz's Avatar
CarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these partsCarShowz is infamous around these parts
Default Indash brake light on while driving
Like the title says the brake light in my guage cluster is on as if I'm riding around with my handbrake up.
I would think that there's a bad switch somewhere, a fuse, or the fact that my brake fluid is in the middle of the resevour(sp?)
Also when I start my car it idles fine but after it gets a lil warm the idle jumps between 1 and 2.5rpm.
hints/suggestions
CarShowz is offline
Old 12-29-2006, 08:46 PM
has a huge dong
VB2NER's Avatar
Default Re: Indash brake light on while driving
check your brake fluid...
VB2NER is offline
Old 12-29-2006, 08:54 PM
U LòÓk Mad !!
CarShowz's Avatar
yea....its in the middle of the Max and Min line.
CarShowz is offline
has a huge dong
VB2NER's Avatar
honda?
VB2NER is offline
Old 12-29-2006, 08:58 PM
TurboPipingSystems
thermal's Avatar
The only thing that will cause that light to come on is in the emergency brake circuitry. Check the switch on your hand brake, it might just be seized with the contacts in the closed position. Cold weather does weird things. That idling problem can be a lot of things. Check the spark plugs to start with.
thermal is offline
jdmsijdm
01-26-2009 03:13 PM
1slowxr4ti
06-14-2008 11:34 AM
Cobra4B
03-11-2007 11:05 AM
The Wok
11-05-2003 05:06 PM
Quick Reply: Indash brake light on while driving
