Impact of gearing on top speed
ATGATT
Assume a car that makes peak hp at 5300rpm and has a 6000rpm redline.
With 2.47 gears, the car can hit 165mph which is at 5500rpm, which is right where the hp curve starts to come back down.
Wtih 2.65 gears, the top speed of the gearing would be 168. Would the car now be able to do 168 because of the multiplication impact of gearing on torque, or would the top speed be reduced because with 2.65 gears 5500rpm comes in at 154 (though, obviously top speed wouldn't be 154 since the air drag is lower - under the second theory I'm thinking it would be around 160 based on the power curves and drag specs)?
Re: Impact of gearing on top speed
With 2.65 gears, the top speed of the gearing would be 168. Would the car now be able to do 168 because of the multiplication impact of gearing on torque, or would the top speed be reduced because with 2.65 gears 5500rpm comes in at 154 (though, obviously top speed wouldn't be 154 since the air drag is lower - under the second theory I'm thinking it would be around 160 based on the power curves and drag specs)?
The power to the wheels would be increased by the lower gear ratio, like you've said. But, drag force increases with the square of velocity, and power is force times velocity, so the power required goes up with the cube of velocity. To put that in context, going twice as fast takes 8 times the power.
The top speed is almost completely governed by the intersection of the drag curve and the peak power output of the engine, and obviously the engine must stay within the RPM range to reach whatever top speed based on the gearing. So the answer is whether the change in gearing produces enough extra power to increase the top speed without reaching the engine redline. I think the answer is no, intuitively at least.
All of this can be calculated pretty easily with only slightly more info than you've already given.
I need to find a pen, a piece of scrap paper, and a calculator. And some motivation. The first three are easy.
ATGATT
Are you speculating or is this a fact based on an actual car...?
The top speed is almost completely governed by the intersection of the drag curve and the peak power output of the engine, and obviously the engine must stay within the RPM range to reach whatever top speed based on the gearing. So the answer is whether the change in gearing produces enough power to increase the top speed without reaching the engine redline. I think the answer is no, intuitively at least.
I need a pen, a piece of scrap paper, and a calculator. And some motivation.
Again though, that only works if you keep the engine within the safe RPM range at that power output.
ATGATT
Ok, I just wasn't sure if I could do a straight multiplication of gearing by horsepower, but then since I know that works for torque and horsepower is a function of torque, it should have been blatantly obvious to me that that's how it works.
So 2.65 would be perfect for the car - after looking at the curves the hp at redline multiplied by 2.65 will be greater than the peak hp multiplied by 2.47.
I'd have to scribble a little math to convince myself, but I think everything should come out in the wash based on the RPM difference.
For a quick refresh, HP= (torque*RPM)/5252
Oh, don't forget the transmission gear ratio too. It should cancel out if you're just calculating a delta but it's not a bad thing to double check.
ATGATT
Now, to find a 2.65 rear end with LSD and ABS.
I can find a 2.24 with both of those, and I could buy a 2.82 ring and pinion gear, which should be fun for acceleration but will drop top speed by gearing to 157.6. I wonder if the 2.65 ring and pinion could be put into the 2.24 since they use the same housing, hmm...to the parts catalog!
