Ignition radio noise help
I <3 BOOST
I just put in my Crane HI-6 ignition, and i cant hardly hear any stations. I know the noise is coming from the ignition, but what can i do to sheild the wires or filter out the noise? Are the high voltage wires the only ones that cause the noise; ie: the wire from the coil to the dist. cap? Any help or ideas are welcome, thanks!
corona connessuer
Re: Ignition radio noise help
check out cranes site, i think they have a section in the directions that deals w/trouble shooting noise. i think it has something to do w/the ground of the ignition. hooked mine up and i don't have any noise at all
Cut,it,out
ground noise isolators dont work for shit so dont bother wasting your money. all i could say is get some good shielded RCAs and try and route any stereo related lines away from any power sources or wires. hope that helps
TTTTIIIMMMAAAAAYYY!
On another note... i wish people would not give false information as its hard to be on the recieving end of this info. Hes looking for a solution not more confusion.
Cut,it,out
just my experience with them. after re routing wires and making sure they were clear of power wires, the noise was gone. so i assumed the isolator wasnt doing anything. i guess in some situations thats different.
Custom User Title
As a general rule, noise in a car stereo is something not grounded well
There are a few things you can do:
put a loop in your coil wire (old trick, worth a try)
wrap your audio signal (RCA) cables in aluminum foil and secure with zip ties (ugly but does work)
buy new high quality RCA cables
ensure your signal and power cables do not run parellel to each other at all anywhere in the car
if your RCA cables have a small wire in the middle of them, I ensure you that is not a remote turn on wire, that is a ground wire. Ground the small wire to the chassis of your radio and to the other end to the body of the car.
I <3 BOOST
its not the RCAs that pick up the signal, the antenna picks up the noise. i guess i could wrap that... also, my coil wire doesnt have enough slack to loop. as far as grounds, everything worked fine b4 the ignition was put in, it even works when the car's not running. the only ground added was the one for the HI-6 box, and i made sure to strip all the paint and sand well. im pretty sure my existing grounds are good, but i could probably use a grounding kit.
TTTTIIIMMMAAAAAYYY!
sircrx
38
04-25-2009 08:46 PM
