idling problem. Pleae help
Old 06-15-2010, 05:14 AM
mugen_power's Avatar
mugen_power mugen_power mugen_power mugen_power mugen_power mugen_power mugen_power mugen_power mugen_power
Default idling problem. Pleae help
i have a 96 civic with a OBD1 GSR. i have a crazy idling problem. the car will run fine holdng arround 700 untill there is a elctrical load like my fans cutting on or turning on y blower fan. then it will begin to drop to 100 all the way to 1000 and fluxuate up and down upand down. it also does this under vaccum load like applying the brakes.
i have replaced both iac valve and map sensor. neeith has fixed it. i thought it was th altnator or bad cell in the batteery but i did a charging system check and it came back fine.
i have no clue what it could be if anyone has any suggestions please feel free.
mugen_power is offline
Old 06-16-2010, 02:20 PM
Shoryuken!
Snoop 95's Avatar
Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95 Snoop 95
Default Re: idling problem. Pleae help
Do you have a gauge to show how much vaccum you're pulling before the problem, and during the problem?
Snoop 95 is offline
Old 06-16-2010, 02:23 PM
management
boredom's Avatar
boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom
check/change your tps. had a similar issue and i changed iacv, tps, map, IM gasket, tb, tb gasket and injectors before mine went away.
boredom is offline
Old 06-16-2010, 02:50 PM
UrGrlGveMeDkBrn's Avatar
UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn
IIRC the 96 has a fit valve. Did you clean it..?...
UrGrlGveMeDkBrn is offline
Old 06-16-2010, 03:31 PM
sbdunkz757's Avatar
sbdunkz757 sbdunkz757 sbdunkz757 sbdunkz757 sbdunkz757
check tps sensor position, i had exact same problem on my gsr, theres a certain angle your supposed to put the tps sensor becuz theres a little needle on the bottom of the sensor that goes on a certain spot on the TB, it goes between the two bars, youll see them
sbdunkz757 is offline
Old 06-18-2010, 06:43 AM
thanks alot gonna check it out this weekend see if any of this stuff helps
tpinoy420
04-13-2004 06:20 PM
94XRolla
02-17-2004 11:55 AM
Jimbo
10-03-2003 03:10 PM
one pnt 8 hatch
08-07-2003 11:11 AM
Stillpushin
04-28-2003 08:41 PM
Quick Reply: idling problem. Pleae help
