Iddle air control valve
anybody know how to fix it?
already checked for vacuum leaks, tps voltage, map sensor, 4 differemt iacv's 2 used ones and 2 brand new ones. its wired up straight to the ecu
and still no go. im f****** tired of messing with it.
thanks in advance.
thanks in advance.
Re: Iddle air control valve
It's wired straight to the ECU, but have you actually checked the wiring? It's possible that you have a broken wire, corrosion inside the wire insulation, or corrosion on the connector terminals. You can swap in parts all you want, but unless you've checked the other things then you're just chasing your tail.
Ohhh Snap
Wow calm down on the bumps but like fabrik said,check the actual pig tail connector that goes into the ecu,my vtec wiring did the same on my car till i swapped out the pins on the plug.
