I seriously need some help with my CA18DET
Old 05-01-2006, 03:42 PM
Wickedy Wick's Avatar
Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick Wickedy Wick
Default I seriously need some help with my CA18DET
Here is my problem and only problem:::
After i drive my car for 5 min, my car dies but does not stall. The revs will not go up and i hear HEAVY gargaling coming from the exhaust. The car does not shut off, I just cant drive because the power disappears, no throttle response, even with the pedal down the car does not move, i just hear rumbleing from the exhaust. BEFORE the 5min my car drives GREAT, no hesitation nothing, and it can idle all day long with no problem.
NO ecu codes
My timing is 15deg
Changed fuel filter
TPS is at .5 and 5V
Idle is great at 750
I looked for vacuum and boost leaks for atleast 4 hours today using some carb and choke cleaner.
My Vac is at 20hg
Every injector i pull i notice a big difference in idle, so i guess they all work, same goes with the coilpacks
Fuel Pressure is at 32 on idle and 40 at WOT
Oil pressure is at 20 once the car warms up
I do not have time for this anymore since i work 40hours per week and i have been driving someone elses car for the last three months.
PLEASE HELP Call me if you want to stop by 804-350-3591,
Wickedy Wick is offline
Old 05-03-2006, 05:23 AM
rotation3x's Avatar
rotation3x is an unknown quantity at this point
Default Re: I seriously need some help with my CA18DET
sounds like some minor problems i would go through and check everthing.
rotation3x is offline
Old 05-03-2006, 05:31 AM
I have a 20 valve...
crxnfx's Avatar
as far as your problem, the only thing I can think of that happens after about 5 minutes is that your thermostat will open (not necessary in 5 minutes, but when it reaches the correct temperature).
Your o2 sensor would give you a code.
shit... I subscribing so that I can find out what happens.
crxnfx is offline
Old 05-03-2006, 01:38 PM
rotation3x's Avatar
kinda sounds like turbo
Old 05-03-2006, 04:45 PM
FredVegas
B16ASilverHonda's Avatar
B16ASilverHonda has a spectacular aura aboutB16ASilverHonda has a spectacular aura about
bring it to brauning motorsports, we can fix it for you...
B16ASilverHonda is offline
Old 05-04-2006, 03:21 AM
I know it cant be turbo since its a new GT28R. The CA has no code for the O2,
B16silverhonda I called you this morning and I wanted to let you know that i will be there at 8am this Saturday
Old 05-04-2006, 07:41 AM
H dizzle
according's Avatar
according has disabled reputation
it sounds like an electrical problem, you arent getting full voltage to the sparkplugs, so there is no torque or throttle responce, are your battery and alternater up to par???????
according is offline
Old 05-05-2006, 03:20 AM
I bought a new battery from westco. If my alternator was bad my car would not be able to hold a charge. But im thinking it is something else electrical
Old 05-16-2006, 09:40 AM
Just to let you guys know that it was the 02 sensor
emu103
04-28-2009 06:29 AM
lostmenoggin
10-28-2008 02:32 PM
blksylv
08-31-2007 02:59 AM
sumospeed.com
10-27-2005 06:54 AM
Quick Reply: I seriously need some help with my CA18DET
