I Need Turbo Help
Old 11-26-2002, 06:01 PM
REVcivic89's Avatar
REVcivic89 is an unknown quantity at this point
Default I Need Turbo Help
Ok check it out,I need to knwo what I will need to put a turbo kit on my GSR ENGINE I want the most power i can get and what will I need to do to my internals and everything else to make it as fast as I can and push as much boost as i can. I am seriously looking at trying to figure out how to run like 20+lbs of boost I dont want to be like all the other turbo civics that only can push like 9lbs of boost i want to go BIG and I MEAN BIG I just want to knwo if it is possible The money isnt a problem I just neet to know what I have to do to push that muchboost
Thanks for any info you can give me
REVcivic89 is offline
Old 11-27-2002, 12:58 AM
Hawaii's lone DA
VWeatr's Avatar
VWeatr is an unknown quantity at this point
Golden Eagle sleeves, Crower rods, Stainless valves, JG Edelbrock intake manifold, Hondata or Z-dyne, custom turbo kit, and a shit load of dyno tuning.
^Those are the main parts that need addressing, if money is of no concern then you'll have no problem making 450+HP.
VWeatr is offline
Old 11-27-2002, 04:22 AM
Atheist.
Skywalker's Avatar
Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker Skywalker
Pistons, turbo-spec cams, big turbos, custom pipes & manifolds, Hondata, block girdle, FMIC, boost controller, all the other little turbo parts, lots of tools, and access to a dyno.
Brakes, wheels/tires, and suspension should come first.
For specifics, go to www.honda-acura.net and do a SEARCH.
Skywalker is offline
Old 11-27-2002, 06:19 AM
SPAWN OF A NEW OP!
THE BEAST's Avatar
THE BEAST is an unknown quantity at this point
Dont forget to build the head....port and polish, springs & retainers, valves, cams, etc...CAM GEARS FOR YOU SMART ASSES
****theres no point in building just the bottom end and not the head, especially when your going to run turbo....thats where its at...Endyn is great for head work and Golden Eagle can work block(sleeves).
of course you have to build the block to keep the pistons, rods, and sleeves from disintegrating
THE BEAST is offline
Old 11-27-2002, 03:25 PM
got torque???
turbotwista's Avatar
turbotwista turbotwista turbotwista
you guys are forgetting one thing fuel all that air wont do you any good unless you can match the fuel via bigger injectors, fuel pump, fpr(one that is boost controlled), and some kind of fuel controller(AEM makes a sweet ecu). Boost controller, turbo timer (makes your turbo(s) last longer). I recommend a to4e for your turbo. there is probably more but that is all that is on the top of my head
turbotwista is offline
Old 11-27-2002, 05:54 PM
REVcivic89's Avatar
I want to thank you guys for all of your help is it true that you can push like 16lbs of boost on a t3/t4 turbo
Old 11-27-2002, 06:17 PM
DESTROYS DONUTS !!
MORE IMPATIENT's Avatar
that all depends on what motor you have an whats done to it, i have a stock ls motor and i have a t3/t04e turbo and i run 9 psi everyday and around 12-13 psi at the track, a t3/to4e turbo with a 57 trim , stage 3 wheels and the usual 60 a.r. reaches maximum 100% efficiency at like 23-24psi of boost, thats alot of boost buddy, if you go with a pre assembled turbo kit(may i suggest revhard cause i made the mistake and bought a drag kit) it comes with everthing you need to run it on a stock motored honda, fmu, vaccum lines, bosch high flow fuel pump, ic, turbo, manifold, wastegate, piping, bov, missing link, dump tube, downpipe, all that stuff that comes with the kit is good, and if you want to run lots of boost, just get some new injectors, get rid of the fmu and get a hondata, and build the motor and youll have a beast, its all about money and time brother.......good luck.....
MORE IMPATIENT is offline
Old 11-27-2002, 06:24 PM
Virginia Beach 757
_crs's Avatar
_crs has disabled reputation
Come by the shop and we'll show you a 32psi engine and what it takes. Our engine stands up to this amount of boost on the daily. The one thing that failed on our block is the oil pump. We were using a stock integ.TypeR and that thing FAILED!!! We are now going aftermarket. It all depends on time and money don't expect to buy all the parts and slap it together. We went to ABACUS for our headwork. There really good at what they do. Stop by the shop and we'll talk turbos. Crs_autosolution
_crs is offline
Old 11-28-2002, 10:08 AM
REVcivic89's Avatar
hey man where isyour shop at and will come up there and talk turbos
Old 11-28-2002, 05:20 PM
Virginia Beach 757
_crs's Avatar
We build all kinds of custom turbos at the shop..we have our own fabricator on location if your serious about building a turbo from scratch come by the shop and we can show you what we can do..right now we have 2 turbo projects that were just about to finish. one is a newcelica GT and the other is a ZX2 escort. Our address is in my sig. and the number is above my avatar..thanks crs_autosolution
_crs is offline
Quick Reply: I Need Turbo Help
