I need help w/stripped bolt on the shock.
Old 05-08-2007, 07:59 AM
RoAzn757's Avatar
RoAzn757 has disabled reputation
Default I need help w/stripped bolt on the shock.
Its stripped pretty good. Also I have a bolt that was torqued off. Do I drill through or what? If someone could help that would be awesome.
Mark
RoAzn757 is offline
Old 05-08-2007, 08:05 AM
Stuck on I-66
TehMascot's Avatar
TehMascot TehMascot TehMascot TehMascot TehMascot TehMascot TehMascot TehMascot TehMascot TehMascot TehMascot
Default Re: I need help w/stripped bolt on the shock.
what I've heard that works (albiet a little abstract) is to weld another bolt to the head of the stripped one, and then go at it.
TehMascot is offline
Old 05-08-2007, 10:23 AM
hype-r
Boost609's Avatar
Boost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond reputeBoost609 has a reputation beyond repute
Is any of the threads protruding from the block or is it flush? If there is enough you can maybe use an extractor socket, if it's flush...well start drilling. Be careful and use a smaller drill bit than the actual hole, and make sure you tap it before you try putting another bolt in.
EDIT: I thought I read "block". I'm assuming your working with the rear lower control arm and the bolt through it broke. Give that up, it's not even worth the hassle. Bring the shock and lca down together in one piece, and get a new lca b/c that bolt isn't comin out (I know from alot of experience). If you need the shock, get an impact and snap off the tac welded nut from the shock. May have to do a little cutting, but should manage to get the shock off. Then just use a standard bolt/nut setup when it goes back together.
Boost609 is offline
Old 05-08-2007, 10:26 AM
This is going to spo
tecnic1's Avatar
tecnic1 tecnic1 tecnic1
I did this on my compensator arms
tecnic1 is offline
Old 05-08-2007, 10:45 AM
RoAzn757's Avatar
Yea I've got another set of shocks and springs Im putting on there. So I drilled it pretty good so Im thinking of just cutting the shock prong on the other side of bolt where it is threaded so I can just get a socket and just turn it till I can pull it through. Think it is a good idea or what.
Mark
RoAzn757 is offline
Old 05-08-2007, 10:51 AM
hype-r
Boost609's Avatar
I'm telling you dude...it will be a miracle for you to get that bolt out of the lca. You can try, but most likely will need a new one. Buy some aftermarkets, or call a junkyard. I had to end up getting one from some place out in Bower's Hill. No yard around here will having anything for a civic/integra for very long.
Boost609 is offline
Old 05-09-2007, 09:51 AM
corona connessuer
CHAHONDA's Avatar
i have tegs and civics
CHAHONDA is offline
00si
09-26-2008 05:23 PM
CTR
01-22-2007 07:13 AM
boostedgst97
12-17-2006 07:21 AM
PRO-Habit
02-10-2006 03:37 PM
TPJ
07-29-2004 06:27 PM
Quick Reply: I need help w/stripped bolt on the shock.
