I Need help with turbo set up
Old 05-06-2009, 04:39 AM
ekkiller's Avatar
ekkiller has disabled reputation
Default I Need help with turbo set up
i just finish my eg single cam non vtec turbo set up. i dint think it would run like this but i dont know whats going on. the car runs in limp mode im runing a FMU and when i hit 3200 to 4200 the car starts to choke and back fires alot and the check engine light comes on and the car cut off if any of u guys know wut could be wrong please help thanks
ekkiller is offline
Old 05-06-2009, 04:40 AM
Slammedxpert
SortaFlush's Avatar
Default Re: I Need help with turbo set up
How many lbs of boost are you on?
SortaFlush is offline
Old 05-06-2009, 11:51 AM
vxcoastie's Avatar
vxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to allvxcoastie is a name known to all
Are you running a check valve between the throttlebody and MAP sensor??
Also, whats your engine setup and what year?
vxcoastie is offline
Old 05-06-2009, 08:23 PM
eclispegs2008's Avatar
eclispegs2008 has disabled reputation
the stock map can only handle 10psi, so if youre over that, that may be causing it. missing links and fmu's are the worse kind tuning aids. You need to be running a safc at least, crome or hondata wold be better though
eclispegs2008 is offline
Old 05-06-2009, 09:30 PM
CPL Us Army
jpick_aap_cpp's Avatar
jpick_aap_cpp has disabled reputation
Boost leak?! need some more information about the vehicle to be able to figure out the cause of the problem.
jpick_aap_cpp is offline
ZipTiedCoupe
Engine / Exhaust / Drivetrain
04-24-2009 08:20 PM
klownh8er
08-17-2008 10:08 PM
Quick Reply: I Need help with turbo set up
