I NEED HELP!. LOWERING SPRINGS AND GAS SHOCKS
Old 12-02-2009, 01:30 PM
DSM?FUCK
Honda Rizz's Avatar
Honda Rizz has disabled reputation
Exclamation .
Honda Rizz is offline
Old 12-02-2009, 01:55 PM
Mindless's Avatar
Mindless is an unknown quantity at this point
Default Re: I NEED HELP!. LOWERING SPRINGS AND GAS SHOCKS
No, use the shocks only.
Mindless is offline
Old 12-02-2009, 02:16 PM
DSM?FUCK
Honda Rizz's Avatar
use the shock only?. but dont i need the lowering springs to lower it?
Old 12-02-2009, 02:26 PM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
Lol @ Mindless.
What you could do (and what most people do that lower their cars the "cheap" way) is get some Ebay springs and put them on your stock struts. But don't complain when you're buying new tires every few months because your camber is so damn negative.
Do yourself a favor and save up some money for an actual coilover setup. It'll give you that dropped, stiff ride you're looking for but, without the bounciness. Make sure you get a camber kit as well.
backtoarms is offline
Old 12-02-2009, 02:29 PM
DSM?FUCK
Honda Rizz's Avatar
well the previouse owner said he had it lowered on the shocks and the lowering springs. so are yall saying it wont work? or it wouldnt be a good idea?. cause thats all i have to lower it
Old 12-02-2009, 02:30 PM
psycho jungle cat
Spindrift's Avatar
wow...
Spindrift is offline
Old 12-02-2009, 02:33 PM
backtoarms's Avatar
Stock struts + lowering springs = bouncy ass ride.
It's doable. And you MIGHT like it. Depends on if you like bouncing over EVERY bump or not. It's good if girls are riding shotgun. :P
Just imagine because your struts will be bottomed out. So when you hit a bump your struts can't be pressed in any further so it'll only shoot out. I had an EK coupe that I ran the lowing springs on stock struts setup for a while. My friends would come push on my trunk and make my car LITERALLY bounce the tires off the ground because the recoil was so strong.
Needless to say, I learned my lesson. Now, I'm running Blox everything.
Old 12-02-2009, 02:36 PM
You'll only get a bouncy ride if you have stiff springs and not enough damping. Other than that you'll just have a firm ride with lowering springs. The see-saw that you often see cars do when they're lowered is from not enough damping and front/rear springs that are too close to the same spring rate.
You should get a camber kit though, because of the obvious tire wear problems.
But no, there is no reason that you can't use OEM fitment lowering springs on OEM fitment shocks. I'd rather have a decent set of aftermarket dampers and a good set of lowering springs than a crap set of "me-too" coilovers.
Old 12-02-2009, 02:39 PM
DSM?FUCK
Honda Rizz's Avatar
lmfao. yeah true. well i have megan front and back strut bars on there. and the AGX adjustable shocks. but that wont lower it. if i put the lowering springs on the shocks wont that work good?
Old 12-02-2009, 03:09 PM
backtoarms's Avatar
My bad, I misread the original post. I thought you were putting lowering springs on OEM struts.
Quick Reply: I NEED HELP!. LOWERING SPRINGS AND GAS SHOCKS
