How To Wire A Battery Killswitch DIY
Old 02-15-2010, 06:43 PM
YANKYMATE!
lbs_ft's Avatar
Default How To Wire A Battery Killswitch DIY
as you all may or may not know, i've got a horrible drain on my battery (3.70 amps while the car is off) and after spending an entire week filled with blood, sweat, and tears (not to mention my hard-earned cash) and still ending up with a dead battery after only a few hours, i've decided to wire up a killswitch.
after reading up for a while, i think i want to run a thick wire (dunno what gauge) from the negative cable back up though the firewall, through a killswitch mounted under the dash, then back out through the firewall to the negative post on the battery.
will this work? not trying to destroy my car after all this work. would this prevent my battery from being drained everytime i leave it sitting? would this allow the battery to remain fully charged at 12 volts for an indefinite amount of time? is this safe?
and what parts do i need? what gauge wire and where and what kind of killswitch?
thanks in advance
lbs_ft is offline
Old 02-15-2010, 06:52 PM
I Love to Hate
B-Well's Avatar
Default Re: How To Wire A Battery Killswitch DIY
yes you can do this. either with a circuit breaker or a switch.
you can place the switch in the glove box to limit the amout of hot wire running around the car.
4gauge will be plenty big for this setup. no need for overkill
if you plan to do the switch it is still a good idea to run a fuse (80a) or a circuit breaker (80a) in conjunction. that way if a wire gets skinned and grounds out there wont be any fires .
B-Well is offline
Old 02-15-2010, 07:02 PM
YANKYMATE!
lbs_ft's Avatar
thanks bud, thats almost all the info i need
what size circuit breaker do you think will do the trick?
lbs_ft is offline
Old 02-15-2010, 07:05 PM
I Love to Hate
B-Well's Avatar
i told ya in the last post lol
(80a)
B-Well is offline
Old 02-15-2010, 07:06 PM
I Love to Hate
B-Well's Avatar
also, be sure the car is completely off before you hit that kill switch or you may risk burning up the computer.
B-Well is offline
Old 02-15-2010, 07:07 PM
YANKYMATE!
lbs_ft's Avatar
(80a)
well, i'm retarded.
looks like they make kill switches for batteries that come with removable keys.
had any experience with those? know where i could pick one up locally, or would i have to order one do you think?
lbs_ft is offline
Old 02-15-2010, 07:20 PM
I'm still not convinced that you've done very much to find the problem. You need some outside help probably.
Old 02-15-2010, 07:22 PM
Function > Form
6CYLINDRSYMPHNY's Avatar
Sell me your Jetta.
6CYLINDRSYMPHNY is offline
RandomTask's Avatar
Bust out a voltmeter. A 3.7amp drain is a lot.
RandomTask is offline
Old 02-15-2010, 07:24 PM
YANKYMATE!
lbs_ft's Avatar
i've gotten all my buddies in on it, and the end result is that we've spent a week tearing every electronic component apart... its gonna take me another week to put everything back to the way it was haha
i don't really know what else to do - trust me, this is the last thing i want... i'd prefer to just have her stock
Originally Posted by 6CYLINDRSYMPHNY
Sell me your GTI.
don't have a GTI, its a GL
i don't understand what you're getting at
http://forums.vwvortex.com/zerothread?id=4759977&page=1
lbs_ft is offline
Quick Reply: How To Wire A Battery Killswitch DIY
