How to reset 95 accord srs light
Help is mucho needed....i know whats wrong its my fault nothing wrong with the airbags or srs system just needa reset the light...any advice?....i read about juming the mes connector but i dead scared ill deploy the airbags
car is a 1995 honda accord
in search of light
Re: How to reset 95 accord srs light
First, locate the MES connector and unplug it.Use a small guage speaker wires with both end strip.Insert one end of speaker wires into MES plug (one wire each contact)
Short and hold the leads while you turn the ignition to on. The SRS Light will illuminate for a few seconds then go off.
-When the SRS Light goes off, unshort the wires. The SRS Light will come back on.
-Short and hold the wires again. The SRS Light will go off.
-When the SRS Light goes off, unshort the wires. The SRS Light will blink twice.
-Turn the ignition off.
-Start engine as normal. The SRS Light should illuminate for a couple of seconds as normal and then go off.
(4a) This series of shorting/unshorting needs to take place within a 4 second window of the SRS Light going on/off each time.
Hope this help...
__________________
Hope this help...
__________________
yeah thanks guys....i was trippin that id blow the airbags so i went and paid someone 40 bucks to do this 10 min job and the guy couldnt even find the mes connector i hadda show him where it was... and for anyone else who reads this....IT IS THE RIGHT WAY
