Hot starting problems
Old 12-30-2006, 01:33 PM
Awesome
RtryPwr's Avatar
RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr RtryPwr
Default Hot starting problems
Hey everyone, this is my first post on here. I am having a problem with my 87 Rx7 TII. It has a really hard time starting when it is warmed up. I takes like 3-7 cranks on the starter before it will start. Any ideas?
RtryPwr is offline
Old 12-31-2006, 03:09 AM
zoom zoom
mikesnacivic's Avatar
mikesnacivic is an unknown quantity at this point
Default Re: Hot starting problems
How's your maintenance? The first thing I think of here is plugs/wires, injectors, air filter. When it does start up how well does it run?
mikesnacivic is offline
Old 12-31-2006, 04:57 AM
Awesome
RtryPwr's Avatar
After it cranks up, it hesitates a little. After about 5 second of hesitation, it kicks the rpms up to a steady idle and runs fine.
The air filter is new, not sure about the plugs, wires, and injectors.
RtryPwr is offline
Old 01-02-2007, 06:57 AM
Rotaryhaven
jerryrx7's Avatar
jerryrx7 is an unknown quantity at this point
Check compression, vacuum leaks and tps adjustment....If all is ok, you might need a tuneup. Fuel injectors can be flooding, pour some bg44k injector cleaner that is sold by the auto dealers. Don't buy the junk from chain auto part stores....
jerryrx7 is offline
slewis79
04-22-2008 09:10 PM
M1KeyC
11-03-2007 01:07 AM
AquaDrake
12-20-2005 06:12 PM
Ej8D16y8-T
12-06-2005 01:02 PM
beanslimm
10-28-2005 12:48 PM
Quick Reply: Hot starting problems
