HONDA WONT BUILD BOOST PLEASE HELP!!!
Old 08-18-2011, 10:46 AM
aa4baseball's Avatar
aa4baseball has disabled reputation
Default HONDA WONT BUILD BOOST PLEASE HELP!!!
I have a 92 Integra. Stock ls motor with 55k on it. .63 a/r .54 trim jdm sport turbo. 450cc dsms. walbro 255. inlinepro bov. emusa 38mm wastegate. a few pinholes in exhaust manifold (pinholes were covered with epoxy until it burnt off and had no real affect on anything. 2.25" downpipe. 2" ic lines.
My car is basemapped but still untuned because when i went to get it tuned it wouldnt build boost.
It will build to 2-3 psi near WOT except for in 1st it doesnt want to seem to build at all. I just had compression checked and all cylinders were 140-150. and they said my timing was perfect. Ive checked for leaks in ic lines several times and cant find ANY. Ive also used a air compressor and checked wastegate actuator and it opens at 10psi as it should.
SOMEBODY PLEASE HELP ME both the wastegate and bov were bought used.
COULD my boost gauge be reading wrong i have it spliced into fpr
I FORGOT TO PUT THAT MY BOOST GAUGE READS IM IDLING AROUND 15 INHG. As opposed to 21 inHG where i am told it should be.
aa4baseball is offline
Old 08-18-2011, 10:58 AM
fuckin smart
Mortal_Meerkat's Avatar
Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat Mortal_Meerkat
Default Re: HONDA WONT BUILD BOOST PLEASE HELP!!!
Originally Posted by aa4baseball
I have a 92 Integra. Stock ls motor with 55k on it. .63 a/r .54 trim turbo. 450cc dsms. walbro 255. inlinepro bov. emusa 38mm wastegate. a few pinholes in exhaust manifold. 2.25" downpipe. 2" ic lines.
wrong section.
Mortal_Meerkat is offline
Old 08-18-2011, 11:11 AM
last breath first
gdupfromfeetup's Avatar
gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup gdupfromfeetup
do you have a resistor box wired in for your injectors?
gdupfromfeetup is offline
Old 08-18-2011, 11:47 AM
DURHUR's Avatar
Post pictures of your setup...that will help us diagnose if you've got anything installed incorrectly.
DURHUR is offline
twinturbomeow's Avatar
twinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these partstwinturbomeow is infamous around these parts
start by posting this in tech talk
twinturbomeow is offline
Old 08-18-2011, 11:53 AM
i pooped a squirrel
Gen_Crunchytoes's Avatar
Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes
Fix the exhaust manifold, that's where your problem is. How would you possibly think that holes in the exhaust manifold wouldn't be a problem
Gen_Crunchytoes is offline
Old 08-18-2011, 12:11 PM
hondaslutt's Avatar
hondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these partshondaslutt is infamous around these parts
if theres holes in your exhauast manifold, its not that you arent building boost. its that your leaking it. fix that. i bet itll build just fine.
hondaslutt is offline
Old 08-18-2011, 01:45 PM
NOt rep'n the g1teg
popwars123's Avatar
popwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond reputepopwars123 has a reputation beyond repute
its either those holes, or wastegate diaphragm leaking by.
popwars123 is offline
Old 08-18-2011, 04:12 PM
ChokolAwt's Avatar
ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt
its also common practice to tap your boost gauge into the intake manifold, not the fpr.
ChokolAwt is offline
Old 08-18-2011, 04:15 PM
Dickbutt #peentip
Kris.Is.Foamin's Avatar
/facepalm.
Kris.Is.Foamin is offline
Quick Reply: HONDA WONT BUILD BOOST PLEASE HELP!!!
