honda trouble code problem
Old 02-21-2008, 06:51 AM
rollinondubz's Avatar
rollinondubz has disabled reputation
Default honda trouble code problem
i have a 97 ek with an ls/vtec.. gsr headand tranny and b18b block w/ p72 ecu (not that it matters) thats throwing a P1337 manufacture cntrlled ignition misfire... i checked the resistance between the 2 pins on the ckf sensor.. it has 1.8 ohms. there is no continuity. so i know the sensor is working.. now i replaced a cam seal not too long ago and i had problems tightening the timing belt.. if the gears are off a tooth or two.. would that trigger the engine light?? everytime i reset the light it comes right back on when i start the engine.. ANY help is highly appreciated
oh and check my threads.. ha
derek
rollinondubz is offline
bsershatch
11-06-2008 10:04 PM
ShaneJeffers28
05-26-2007 04:54 AM
mini-meturbodx
10-10-2005 09:48 AM
Skillz
07-23-2004 06:32 PM
BAGOHO
02-09-2004 07:53 AM
Quick Reply: honda trouble code problem
