Honda idle problem...
Old 12-21-2003, 05:07 PM
nickyroo's Avatar
Default Honda idle problem...
hey my 1995 honda prelude (h23) recently has had an idle problem. when it is in park (A/T) the idle will surge to 1500 then drop to around 800 and do this until it goes into a gear. also, when applying the brakes in park the idle will drop around 600 and the car will almost stall. the pedal feels mushy, brake lines have been bled and fluid is fine. i think the two problems are related somehow seeing as how the idle drops VERY low when the brakes are pressed.
the idle problem sounds like a TPS problem to me, but i have no clue about the second problem. maybe a master cylinder? opinions needed, this crap's annoying and this is my daily driver
nickyroo is offline
Old 12-22-2003, 11:46 AM
nickyroo's Avatar
nickyroo is offline
Old 12-22-2003, 03:00 PM
Type-R; Tight Car
The real Ryan's Avatar
The real Ryan has disabled reputation
i hate the iac valve (idle air control) its a sensor on the back of the throttle body. it should have three bolts holding it on. take it off and spray the screen with a engine cleaner. the screen can get stopped up and cuase this problem. it happend to me so i think its worth a shot.good luck
The real Ryan is offline
Old 12-22-2003, 09:17 PM
emmett18
94b18c1's Avatar
94b18c1 has disabled reputation
mine was the fast idle thermal control valve, under the TB. you wil have to take the TB off to get to it. the wax was loose from racing so much just tighten it if the I.A.C valve is fine
94b18c1 is offline
Old 12-23-2003, 08:56 AM
Boner Jams
-Danimal's Avatar
sounds like a vacuum leak, cuse mine did that exact thing
-Danimal is offline
Old 12-23-2003, 11:12 AM
nickyroo's Avatar
na its had a similar problem before, and it was the TPS. but it wasnt exactly like this. who knows though, might be a vacuum leak. i think it is more electronic though because it stops once it is out of park. i'll let yall know what i find.
nickyroo is offline
Old 12-23-2003, 11:18 AM
Asshole Supreme
S dot Camp's Avatar
Actually, the idle problem sounds like a Idle Air Control Valve. I am not sure about the Brake problem? Booster maybe, but they don't go bad normally.
S dot Camp is offline
Old 12-23-2003, 06:18 PM
been around awhile.
zappas's Avatar
zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas zappas
pcv valve fucked my idle...try that.
zappas is offline
Old 12-23-2003, 06:38 PM
Boosted2003's Avatar
he might have a leak on his brake booster line going to the manifold
Boosted2003 is offline
2tonehatch
03-22-2006 04:33 PM
LastMinuteRacin
12-31-2005 12:34 AM
tegman96
10-18-2004 07:04 AM
2gcivi
06-13-2004 07:44 AM
The real Ryan
04-23-2003 04:11 PM
Quick Reply: Honda idle problem...
