Honda D16Z6 problem??
Old 02-22-2007, 05:16 PM
ooooooooooowwweeeeee
Don_is_Rad's Avatar
Don_is_Rad has disabled reputation
Default Honda D16Z6 problem??
Delete
Don_is_Rad is offline
Old 02-22-2007, 07:06 PM
Don_is_Rad's Avatar
Default Re: Honda D16Z6 problem??
Can I test my Injectors to see wich ones are working??
Old 02-22-2007, 08:47 PM
I fix cars
hondub's Avatar
hondub is an unknown quantity at this point
It sounds like a wiring issue. Make sure all the injectors are getting power and ground.
hondub is offline
Old 02-23-2007, 06:31 AM
Don_is_Rad's Avatar
can I bench test the injectors
Old 02-23-2007, 06:43 AM
I fix cars
hondub's Avatar
You can do a resistance check across the injectors as long and they are disconnected. This will only test the injectors though, nothing else. I dont know where to find the spec for them, im sure you can search honda tech and find it.
hondub is offline
Don_is_Rad's Avatar
A Honda Tech guy told me to run the car and pull one at a time the fuel injector clip. The change or lack of change in idle should give me an answer.
Old 02-23-2007, 06:47 AM
I fix cars
hondub's Avatar
Ahhh, I must be slipping haha. Thats definately a good way to check. You have to wait a second though before anything will change. Usually it takes like 5 seconds for the lack of fuel to affect the idle. Try is out.
hondub is offline
Old 02-23-2007, 08:57 AM
Don_is_Rad's Avatar
Could my fuel pressure be off??
How do I check that?
Old 02-23-2007, 10:18 AM
Don_is_Rad's Avatar
still same problem, anyone know what I should try next. From injector closest to the belts to furthest, pull the first plug off and idles rough plug it back in 2nd injextor unpluged idles rough 3rd injector idles rough and stalls out somtimes 4th injector furthest from the belts car dies???
anyone know??
Old 02-23-2007, 06:36 PM
Don_is_Rad's Avatar
Did a Ohm test, From injector closest to the belts to the furthest. 1st has .03 Ohms 2nd 76. Ohms 3rd 76. Ohms 4th 76. Ohms. I got 12 volts with ket on to each positive side of the plug. So im guessing its grounding out some where right??
Quick Reply: Honda D16Z6 problem??
