Honda Accord Overheating Problem...
Old 09-19-2010, 05:46 PM
VADRIVEN IS WHACK!
WaYtOoLoW's Avatar
WaYtOoLoW has disabled reputation
Default Honda Accord Overheating Problem...
My wifes accord has recently started overheating, and it is an odd problem that i have never ran into or ever heard before...her fan does not work when the car is running but as soon as the key hits the off postion it cuts on...you turn the key back on it stops, it's weird, and if you run the heat it heats up quicker? thats the really weird part...if anyone has a f'n clue let me know!
WaYtOoLoW is offline
Old 09-21-2010, 01:31 AM
VADRIVEN IS WHACK!
WaYtOoLoW's Avatar
Default Re: Honda Accord Overheating Problem...
Old 09-21-2010, 04:42 AM
management
boredom's Avatar
boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom boredom
i should probably just talk shit, but one day out of the blue my old accord (260k, original everything pretty much) started overheating on the temp gauge, but everything was cool to the touch. turned out to be a bad thermostat. you should check the thermostat, coolant hoses, radiator, and lastly the HG.
boredom is offline
Old 09-21-2010, 09:15 AM
Mindless's Avatar
Mindless is an unknown quantity at this point
Need more info. Does it overheat at idle? Does it overheat at highway speeds?
Mindless is offline
Old 09-22-2010, 12:24 AM
VADRIVEN IS WHACK!
WaYtOoLoW's Avatar
just at idle
Old 09-22-2010, 04:31 AM
Mindless's Avatar
T-stat pop?
Hardwire the fan and see if it still does it.
Mindless is offline
Old 09-22-2010, 06:28 PM
E F
E F's Avatar
E F E F E F E F E F E F E F E F E F
Any Updates?
E F is offline
Old 09-22-2010, 06:37 PM
13.5:1 Poor Mans R
Kana's Avatar
Kana has disabled reputation
Fan relay?
Kana is offline
Old 09-22-2010, 06:42 PM
Go cry to momma
Nunyabidness's Avatar
Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness
Originally Posted by Kana
Fan relay?
This would be my guess. I'm thinking the relay is shorted inside and it's sending power on the wrong post. I'd make sure you don't have a bum sensor too. Can't always rely on the dash to tell you the whole truth. Hope this helps.
Nunyabidness is offline
Old 09-22-2010, 07:25 PM
VADRIVEN IS WHACK!
WaYtOoLoW's Avatar
thanks for all the replies, i'm going to work on it some this weekend, i was also thinking a relay problem or a sensor problem, maybe i have one of the sensor wires reversed, i've seen that on accords before, if those don't check out it's toggle switch time!
Quick Reply: Honda Accord Overheating Problem...
